Originally posted by redpigeons how do you find a zoom lens for street?
I never even used a zoom lens, I had a K1000 with a 50mm for a long time
and then I just kept buying prime lenses for my need but there are so many situation I wished I had a zoom
I want the 21mm so much...
But I do have the FA 20mm , and no zoom lenses so I might finally get a zoom
maybe that sigma you are using
I have found the Sigma 24-60mm f/2.8 pretty good. Focus can hunt a little and be off in low light but that's also the K10D. Nice and sharp, especially in the middle focal lengths and stopped down to f/4 to f/8, although f/2.8 is quite pretty good too (if focus is right). I find the focal length nice, although 24mm isn't terribly wide and I sometimes want a bit wider. For a standard zoom it's reasonably small, but does have a 77mm front element. I'm certaiinly going to keep it and still use it, I just want to try a less intrusive set-up for street as well.
