02-18-2010, 06:32 PM   #1
Christopher M.W.T's Avatar
Travel Lens Final Decision : Pentax 17-70 SDM Vs Sigma 18-250 HSM
Ok im about to pull the trigger on one or the other.
I like the Pentax because its constant F4.
I like the Sigma because of the zoom range and I hear the HSM is superior to SDM.
Anyone else care to share their thoughts?
02-18-2010, 06:47 PM   #2
Ole
Ole's Avatar
About 85% to 90% of my travel photos are taken at f=70mm or shorter. If that's of any help!
HSM vs SDM - I wouldn't make that a deciding factor. It's about which focal length you need, and the max. aperture.
You could also consider the 17-70 plus an inexpensive telezoom.
02-18-2010, 07:09 PM   #3
I want to travel light and minimise the lenses I'm carrying.
02-18-2010, 08:25 PM   #4
hcc
hcc's Avatar
I think that the key issue is: what do you like to shoot? Do you need the 70-250mm range ?
When I travel with a single lens on the boy, I use the Pentax 18-250mm. The Sigma 18-250mm HSM is a nice substitute: I tried it. If it was for myself, I would take the Sigma 18-250mm HSM because I like to have the 70-250 mm range.
Hope that it may help ...
02-18-2010, 08:57 PM   #5
Well i'm going through Europe and Egypt so mostly scenery and people.
The concern I have as I already have the Sigma 17-70 (which is a decent lens) However I find that the 17-70 is annoying when using the popup flash as its front element half obstructs it.
Where as I understand the Pentax 17-70 doesn't have this issue.
02-18-2010, 09:23 PM   #6
Clicker's Avatar
I would take the 18-250 BUT when you're doing the markets (Egypt) and some of the interiors, you'll need a fast wide prime/zoom.
02-18-2010, 10:09 PM   #7
Yer I've got an FA50mm 1.4 (which is @ Pentax Japan been repaired as we speak)
I am debating whether or not to take my 10-17 Fisheye though lol.
02-19-2010, 12:05 AM   #8
QuoteOriginally posted by hcc Quote
That'd be my choice lens for travel. I've seen several very attractive photos taken with the Pentax 18 - 250. I'm often amazed at it's image quality for a budget lens.
QuoteOriginally posted by C.W Tsorotes Quote
That's an issue with more lenses than you can imagine.
If you don't have one a shoe mounted flash unit is one of the best investments in the photography world. You don't need the best, or even a dedicated system. Something like this one from Cameta will work just fine.
Just make sure that it's safe or digital before you buy it (I checked, and the one I linked to claims it is)
If you can find one that can be used as a slave it's a nice bonus in the future.
02-19-2010, 02:07 AM   #9
sterretje's Avatar
The manual of your camera has a compatibility list (build-in flash versus pentax lens). For the Kx it indicates that there is a problem with focal length smaller than 24mm. You have a K7 (from your signature) so check the manual.
I'll second the idea of getting a small external flash; as 'replacement' for the internal one, it does not even have to have tilt and swivel (although both are useful).
02-19-2010, 03:01 AM   #10
I already have an AF540GZ but not keen on taking it travelling.
02-19-2010, 03:21 AM   #11
17-70. Unless you like to go birding.
02-19-2010, 03:32 AM   #12
I think the 2nd thing is overrall image quality.
Anyone owned or used both to compare?
02-19-2010, 04:01 AM   #13
are they the same size/length?
i dont actually mind carrying extra lenses as long as they're short enough to fit my camera bag's height hehe.
02-19-2010, 07:25 AM   #14
Clicker's Avatar
You'll end up taking 18-250, 10-17 and 50 but if you already have a 50-200? there is no need to get the 18-50 but you might want to pack the flash :ugh:
What body are you using? If a Kx or K20 the low light challenge should be fine with those lenses imo.
02-19-2010, 07:27 AM   #15
I'm with the K7.
I want to avoid carrying the flash if I have to....
hsm, k-mount, pentax, pentax lens, sdm, sigma, slr lens, travel lens
Pentax SDM vs Sigma HSM. Which is better? Peter Zack Pentax SLR Lens Discussion 31 07-27-2009 11:00 AM
seriously considering this... Sigma 18-250 HSM OS for Pentax laissezfaire Pentax SLR Lens Discussion 5 04-21-2009 12:34 PM
Final decision - K10D vs K200D gcap74 Pentax DSLR Discussion 43 04-09-2008 03:47 PM
Lens decision: Pentax 16-45 and 50-200 combo OR 18-250? sweetpapa Pentax SLR Lens Discussion 30 12-07-2007 02:12 PM
Sigma HSM compability with Pentax SDM gawan Pentax SLR Lens Discussion 3 08-02-2007 03:14 PM
All times are GMT -7. The time now is 11:38 AM. | See also: NikonForums.com, part of our network of photo forums!
