02-19-2010, 06:42 AM   #1
Aperture ring frozen.
Hi,
I hadn't used my K 50mm 1:1/4 lens for about a month. i recently had it cleaned, today I tried to change the aperture and I found it difficult to turn. It was momentarily stuck on f1.4, it took a good bit of pressure to get it to turn. It also required firm pressure to turn the ring.
It has been quite cold recently here, temperatures 6-10 celsius, would that affect the lubrication.
thx
02-19-2010, 07:24 AM   #2
Ben_Edict's Avatar
If the lens is actually that cold, it could reduce the viscosity of the lubricant. But it shouldn't. Such a poor performance would tell me, that the people, that did the servicing, are using the wrong (cheap) grease for the job.
Ben
02-19-2010, 08:04 AM   #3
thank you for your reply
aperture, k-mount, pentax lens, pressure, slr lens
Aperture ring fluidity raymeedc Pentax SLR Lens Discussion 4 11-24-2009 05:54 PM
Use of Aperture-Ring 43mm/1.9 -> no aperture data Deimo Pentax SLR Lens Discussion 7 06-24-2009 03:25 PM
Using aperture ring? audiobomber Pentax DSLR Discussion 6 10-07-2008 02:31 PM
Aperture ring on my *ist DL FastPhotography Pentax SLR Lens Discussion 7 12-25-2007 09:53 AM
Can the Aperture ring? kshapero Pentax SLR Lens Discussion 5 10-28-2007 06:25 AM
All times are GMT -7. The time now is 10:52 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
