02-21-2010, 07:25 PM   #1
rustynail925's Avatar
Questions about the Tamron 90mm Macro
I just pruchased this lens and it doesnt have a manual.. to those who own this lens whats up w/ the AF MF ring? whats the purpose of the AF since when you twist the ring it doesnt do anything? and also when i use the lens will i change the cameras using aperture ring setting to permitted?
02-21-2010, 07:34 PM   #2
QuoteOriginally posted by rustynail925 Quote
Pull the ring. Set the aperture to A.
02-21-2010, 07:39 PM   #3
90 macro
Manual downloadable at Tamron USA service
02-21-2010, 07:53 PM   #4
Tamron manuals
I just pruchased this lens and it doesnt have a manual...
You'll find manuals for all the Tamron lenses here.
The manual for the 90mm 2.8 is here.
RTFM.
02-21-2010, 08:26 PM   #5
geauxpez's Avatar
As for the ring -- if it is in the Manual position when you are auto-focusing, the focusing ring will turn in your hand as it focuses (not cool). This allows you to put it in AF mode and have something solid to hold. I'm not exactly sure what you mean by your second question.
02-21-2010, 09:02 PM   #6
Thx for the manual's link..
QuoteOriginally posted by asdf Quote
Thx. How can i set the Aperture to A?
QuoteOriginally posted by geauxpez Quote
What does it mean by
Pictures can be taken even when aperture ring position is other than A?
02-21-2010, 09:23 PM   #7
Jewelltrail's Avatar
For the 90mm Tamron sp Di 90mm 2.8 Macro.
If you want to manually focus with it, pull the focus ring towards you, aligning it with the blue line--now you are set for manual focus.
If you want to use it to Auto Focus, push the ring outwards, aligning it with the white, auto focus line.
If you want apertures to be read by your camera body, align the "A" on the aperture ring with the white vertical line.
If you want to use manual stop down metering, say for extension tube work, push the small, black release pin, located just left of the "A," and turn the ring to the desired aperture setting.
Ask, if you have any more questions.
02-21-2010, 10:47 PM   #8
QuoteOriginally posted by Jewelltrail Quote
What do u mean by that? Whats the purpose of the aperture ring? isnt it better to use just the A and adjust your desired aperture in the camera?
02-21-2010, 11:11 PM   #9
ru
stynail925: What do u mean by that? Whats the purpose of the aperture ring? isnt it better to use just the A and adjust your desired aperture in the camera?
Excellent question, many extension tubes do not afford you the luxury of transmitting aperture back to the camera body--also, with a bellows. In these kinds of conditions, you need to use stop-down metering. Let me know if the pic at this link helps:
http://enticingthelight.files.wordpress.com/2009/01/bellowsdx71.jpg
Without an aperture ring, in these kinds of conditions, where aperture cannot be transmitted back to the body, you would be have a lens with very little utility.
02-22-2010, 05:35 AM   #10
Thx for the help
02-22-2010, 05:52 AM   #11
What is the purpose of extension tubes? is it the same w/ a Macro Conversion Lens?
If an extension tube is connected in a macro lens will it focus closer?
90mm, af, k-mount, lens, macro, pentax lens, questions, slr lens, tamron, tamron 90mm
For Sale - Sold: Pentax K100d + 18-55mm + Tamron 70-300mm; Tamron 90mm Macro jake123 Sold Items 4 11-09-2009 12:51 PM
Tamron 90mm Macro w Tele Questions Jewelltrail Pentax SLR Lens Discussion 8 03-21-2009 06:45 PM
Macro handling questions: Tamron 90mm SP and Pentax DFA 100mm troyz Pentax SLR Lens Discussion 3 02-22-2009 01:17 PM
Tamron 90mm macro digital AF questions Kind_Karma Photographic Technique 3 08-15-2008 06:41 AM
For Sale - Sold: Tamron SP 90mm/2.8 macro (AF), Tamron SP 90mm/2.5 macro (MF) chemxaj Sold Items 11 06-19-2008 08:36 PM
All times are GMT -7. The time now is 06:31 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
