02-22-2010, 10:30 AM   #1
cheekygeek's Avatar
Adaptall teleconverter (mount) question...
I've never owned a Tamron adaptall lens before, but I have a 90mm SP f2.5 with PK mount on the way. That lens only reaches 1:2 without the Tamron teleconverter. But I'm not sure if I need to find a teleconverter with a PK mount, or if you remove the PK mount from the lens... attach the teleconverter...and put the PK mount on the teleconverter. In otherwords... with an Adaptall teleconverter do you actually need TWO PK adaptall mounts (one each for the lens and teleconverter) or just the one?
TIA for the enlightenment!
02-22-2010, 10:33 AM   #2
Blue's Avatar
The SP adaptall converters go between the adaptall lens and your mount. There is also a tube that goes with these macro lenses that make them 1:1 without magnification.
02-22-2010, 10:36 AM   #3
Blue's Avatar
There is an example at the bottom of this brochure.
From Adaptall-2.com
02-22-2010, 10:59 AM   #4
Blue is correct. Remove Adaptall-2 PK mount from lens and attach it to the TC, then mount TC on lens.
02-22-2010, 12:05 PM   #5
cheekygeek's Avatar
Super. That's what I was HOPING!
adaptall, k-mount, lens, pentax lens, pk, slr lens, tamron, teleconverter
quick adaptall mount difference question tvfd911 Pentax SLR Lens Discussion 4 12-21-2009 01:29 PM
Adaptall 1 lens with Adaptall 2 to EOS mount Squier Pentax SLR Lens Discussion 0 08-04-2009 01:35 PM
Tamron Adaptall-2 Mount Question rayallen Pentax SLR Lens Discussion 7 04-28-2009 04:37 PM
Will an Adaptall-one k-mount adapter work on an Adaptall-TWO lens? Grimlock Pentax SLR Lens Discussion 1 02-07-2008 04:18 PM
All times are GMT -7. The time now is 11:33 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
