02-25-2010, 08:12 PM   #1
Low light telephoto candid photography
Hi, I've been doing a lot of research on dslr and lens, specifically for candid photography. I enjoy doing candid street photography at night, but my budget is only about $600. Most of these shots would be hand-held with subject moving at moderate speed. The only source of light would probably be streetlamps. Figuring out what to buy is difficult because I don't have any experience as to how fast the lens need to be to adequately meet the need without going over the budget. Would a 70-200mm f/2.8 be absolutely necessary in these kinds of situation? If one were to use the new k-x body and crank up the ISO, would a slower and cheaper 55-300mm, or 70-300mm f/4-5.8 lens be sufficient? I'm going back and forth between which way would be the cheapest, a k100d body with fast lens or k-x with slow lens. Would the k-x 's capability at shooting high iso and faster autofocus be enough to offset a slow lens? One other important factor is fast autofocus. Ideally, the k-x with a fast 70-200 f/2.8 lens would be an optimal setup, but I do not have the budget for that right now. I would love it if fellow members can chime in, maybe post some shots in similar situation and give me some advice, thanks. Edit: I'm not a pixel peeper and I do not mind if there are noise, as long as the details are still preserved and shutter speed are fast enough to prevent trailing.
02-25-2010, 08:19 PM   #2
PrimeObjectif's Avatar
I still think you're gonna need a fast lens whether or not you go with the K-x. A 70-200 f/2.8 is a huge lens, which'll be hard to carry around and also not very discrete. How far away will you be from your subject? You might do well with a Pentax or Sigma 50mm 1.4, or the DA 70 or FA 77.
02-25-2010, 08:25 PM   #3
QuoteOriginally posted by PrimeObjectif Quote
I would be staking out in cars or on top of buildings. 50mm won't do. I like to get a good closed up shot of their face. I'm starting to think that high iso of k-x won't even be enough with slow lens. Perhaps I'll get the k100d with the 70-300mm f/4-5.8 tamron or sigma and save up for a 70-200mm f/2.8 later. However, then the fast lens performance may be crippled by the k100d slow autofocus.
02-25-2010, 09:33 PM   #4
Marc Sabatella's Avatar
I think your expectations may be unrealistic here on a few fronts. Shooting outdoors at night from long distances, I wouldn't expect AF to be worth two cents no matter which camera you deal with. And even with f/2.8 and ISO 6400 you'll still be struggling freeze subjects moving at "moderate speed". What you're describing is not going to easy at all, but with a 70-300/4-5.6, you'll mostly be getting noisy blurs, I'd imagine, and mostly by switching to MF mode - in AF mode, you'll struggle to get anything at all.
02-25-2010, 09:51 PM   #5
Thanks for the reality check. I think I would be happy to accomplish this feat in full daylight for now. The decision then is to get a cheap body like the k100d and a good lens like the da 55-300mm or the new k-x and compromise on lens quality. In particular, I find that pentax lens tends to be more expensive than canon and nikon, but I'm forced to go with pentax because of their AA batteries.
02-26-2010, 01:48 AM   #6
QuoteOriginally posted by auto210035 Quote
If you think 135mm will be long enough then buy the K-X and a Pentax K 135mm F2.5. You will have to cope with manual focus, but it's not THAT difficult. A prime works fine except when you're sitting in a car. You can also get the K100D body and the K 200mm F2.5, but that lens is quite big and heavy.
Kind regards
.lars
02-26-2010, 05:43 AM   #7
dadipentak's Avatar
QuoteOriginally posted by Recercare Quote
Kind regards
.lars
I haven't tried it outdoors at night but I use the FA 135mm f/2.8 for indoor candid portraits: the IQ is very nice and it's much more discreet than a 70-200mm.
02-26-2010, 06:35 AM   #8
I have a simple solution for you to get quality night shots without a flash. Discard your Pentax, buy a Canon body, with a battery pack, and then invest in a Canon EF 85mm f/1.2. The lens itself will go for no less than $2200.. certainly quite cheaper than any pentax lens. Do your research!
As Marc has said, you are more or less asking for the impossible. Forget about 2.8 with the K-x for what you want to do. The closest thing I could imagine you getting somewhere with, on your mission, would be with a K20D or K7 with an FA* 85/1.4. Don't expect this to be easy to find.
As for manual focus, an A* 135/1.8 exists but this could be also very hard to find.
02-26-2010, 09:03 AM   #9
tokyoso's Avatar
Can you drive and take pictures at the same time?
if you just want an idea, this is a tammy 70-300 shot at ISO 12800 1/100s 300mm... with my shaky hands (too much coffee) and crappy photography skills. i have some face shots but its not what you would call portraits.
i think the paparazzi's use a 2.8 zoom. or something... here's a video i found:
Photo Grind! Inside a Paparazzi’s camera bag
02-26-2010, 09:17 AM   #10
QuoteOriginally posted by tokyoso Quote
I certainly did not expect that. Well, for now, I bought a refurbished k100d and a used tamron 70-300mm ld (non-di) for $80. I'll be saving up for a 70-200 f/2.8, someone please chime in if that too won't be adequate. I'll probably get the k-x body in due time when there are more second hand or refurbished on the market. After looking through flickr, I saw that most night candid are taken with canon 5d and some kind of fast prime. Others are taken in the range of slightly >100mm with iso cranked all the way up to 3200. I actually think it's possible to accomplish this with the k-x on maximum iso and a 70-200 f/2.8 with steady hands and some support.
02-26-2010, 09:38 AM   #11
tokyoso's Avatar
I think it's possible (depending on your township's criteria for a well lit street, but why would you want to do that when you can just walk up close and take a snap ?
no one will see your camera at night, unless your flash fires
02-26-2010, 09:54 AM   #12
That's taking away half the fun of it. Besides, city folks are rather cranky. Do it long enough and your gear will get smashed or worse.
02-26-2010, 10:02 AM   #13
RioRico's Avatar
And my id-monster blurts out: go manual
As noted above, low-light autofocus is flaky. If you know where your subjects will be, prefocus on a specific spot, shoot'em when they get there. For this, an AF fast lens isn't required. So I use a Vivitar Series I Ver.1 70-210/3.5, just 1/2-stop slower and infinitely less expensive than any 80-200/2.8 (cost me $30 on eBay). Pump up the ISO by 1/2 stop to compensate. Hey, it's a night candid, not a studio portrait.
02-26-2010, 10:59 AM   #14
I really doubt you'll do much better on price than the K-x kit that includes the 55-300. *Some* lenses are more expensive for Pentax than for Canon or Nikon, but the 55-300 is one of Pentax's gems, and in the K-x kit, it's a *steal*.
02-26-2010, 06:09 PM   #15
tokyoso's Avatar
you still have to get moderately close to them with a 300mm... isn't it more fun to bring a pepper spray and a P&S unless you're in a really rough neighborhood... but if youre talking guns and stuff i dont think that 300mm lens will do you any good either.
autofocus, body, budget, f/2.8, iso, k-mount, k-x, lens, pentax lens, photography, shots, slr lens
Fast Lens telephoto for low light concert photography? superfuzzy Pentax SLR Lens Discussion 49 12-02-2009 12:24 AM
Help-Taking Candid Pictures of People in Low Light trickashay Troubleshooting and Beginner Help 13 11-22-2009 04:22 PM
Low Light Photography Iann Cannon Troubleshooting and Beginner Help 37 10-22-2009 11:51 AM
Low light photography with a spotmatic? miniheli Film SLRs and Compact Film Cameras 29 10-03-2008 07:14 PM
Low Light photography kshapero Pentax DSLR Discussion 8 06-27-2008 11:03 AM
All times are GMT -7. The time now is 09:54 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
