Originally posted by EddyinGA I've just had my first opportunity to use a fully manual lens on my K100D. What a neat set up it is.
Isn't that great how Pentax implemented support for K and M lenses with AE-L to stop down, meter, and set exposure? Better than with the old film bodies!
Hint: I suggest you to change AE-L functionality in the custom menu to "Tv Shift". That way AE-L will work the same way with ALL lenses setting shutter speed based on aperture for anything you mount on your camera. (You can even use a glass, jar or an ashtray instead of a lens and it would work the same way producing properly exposed frame!!! Amazing!)
Did you know that when using DOF preview with K and M lenses camera stops down the apreture and
turns on the meter so you can actually change aperture and see real-time how that affects metering? Like with old film bodies. That way you can set shutter speed and change aperture to your preference, no AE-L needed. Also, if using spot meter holding down DOF preview lets you explore the scene.
BTW, M50/2 looks great mounted on a DS or K100D :-)
