02-27-2010, 03:46 PM   #1
fccwpe's Avatar
HELP!!!! Sigma 150-500mm Problem
I have had the Sigma 150-500mm for about a week and it has worked flawlessly. However, just a few minutes ago, the AF stopped functioning. The switches on both camera and lens are in AF positions, but when I turn the camera on with the lens attached, it shows MF on the initial info screen. This occurs on both my K20D and Kx. In addition, on the K20D, I can't access any menus or use the function key. When I press a button, the screen flashes to the correct display but goes blank within 1/2 second. All other lenses work fine. Is there something that the HSM motor is doing? I think the lens may be hosed and I should send it back. Has anyone had this problem or something similar before?
02-27-2010, 10:56 PM   #2
If it's a One Week Old lens then Yes, Send it back. Sigma's a good company and will most likely have it fixed quickly.
02-27-2010, 11:45 PM   #3
there is a boton on lensess thich have bad conection to the camera and dont let the AFwork
go to labaratory of sigma they can rise and repair the conections to make beter contacts
this is going resolve your problem
03-01-2010, 08:30 PM   #4
fccwpe's Avatar
Thanks for all the input. I Shipped off to C.R.I.S. in Arizona this morning. They said that it should be a 2-4 week turn around depending on parts support. We'll see.....
Thanks again!!
af, camera, k-mount, k20d, lens, pentax lens, screen, sigma, slr lens
Nature Sigma 150-500mm first pictures fccwpe Post Your Photos! 9 05-14-2010 08:54 PM
Wanted - Acquired: Sigma 50-500mm (BigMa) or 150-500mm Malsi Sold Items 0 03-01-2010 06:01 AM
Sigma 50-500mm vs 150-500mm or Pentax DA 55-300mm with 1.4 TC? mikejustice Pentax SLR Lens Discussion 20 12-18-2009 07:59 PM
Sigma 150-500mm shots Fl_Gulfer Pentax SLR Lens Discussion 6 01-24-2009 11:14 AM
Sigma 150-500mm F5-6.3 DG Where is it??? Scout Pro Pentax SLR Lens Discussion 7 05-13-2008 05:13 PM
All times are GMT -7. The time now is 01:18 AM. | See also: NikonForums.com, part of our network of photo forums!
