03-01-2010, 01:38 AM   #1
octavmandru's Avatar
focal length discrepancy
I recently bought a Pentax 70-200/f4.
the lens is fine for it's price, but I was surprised to notice a HUGE discrepancy when comparing the magnification with my Tamron 28-200.
I am using an ME (can't beat that viewfinder), one tripod and two light stands.
With the ME on the tripod and the Tamron at 200 mm, I placed the lightstands over the the edges of the image in the viewfinder.
Measured the distance between the lighstands: 400 mm @ 1750 mm (1750 mm is the distance from the film to the lightstands.)
Mounted now the Pentax 70-200 @ 200 mm.
If I check the equivalent focal lenghts on the scale results that 200 mm on the Tamron is equal to 110 mm on the Pentax.
OK, I put now the Pentax at 200 mm. Adjusted again the lightstands over the edges of the image in the viewfinder:
Measured the distance between the lighstands: 220 mm @ 1750 mm
Hmmm. 220 V 400. That's a big difference, isn't it?
Ok, I make some calculations now on the paper:
1750-200=1550 mm (distance from the optical center of the lenses to the object)
a1 = angle of Pentax lens @ 200 mm
a2 = angle of Tamron lens @ 200 mm
a1 = 2 arctg 110/1550 = 8,1 degrees
a2 = 2 arctg 200/1550 = 14,7 degrees
So.... What about that?
Octav
03-01-2010, 03:11 AM   #2
The focal length of lenses with internal focus changes as they focus closer. That is likely your problem. The focal length is only accurate at infinity.
03-01-2010, 03:52 AM   #3
Ben_Edict's Avatar
QuoteOriginally posted by flyer Quote
Exactly… Older lenses without IF and generally a simpler construction, will not exhibit such a severe discrepancy of the focal lengthes at near and infinite distances.
Ben
03-01-2010, 05:26 AM   #4
Lowell Goudge's Avatar
aside from what others have posted, I think it is a mistake to use 200 mm as the optical center of the lens.
What I do is set the distance from the front element not the film plane,
once the light has begun to be bent around it is really hard to tell the true optical center,
03-01-2010, 06:07 AM   #5
Interesting... So according my calculations, the Pentax 70-200 is in fact 300 mm at that distance!
200 mm corresponds to an angle-of view of about 12,34 degrees.
I feel like I did a great deal, even if it's just me. Well, better this than tricking myself with the crop factor
Octav
03-01-2010, 06:45 AM   #6
jimH's Avatar
What I did didn't involve any measuring but I've noticed that the image size that I produced from the same distance with a Pentax FA 50mm f/1.4 was noticeably larger than the same image taken with a Tamron AF 17-50 f/2.8 lens set at 50 mm. I was amazed by this since they were both supposedly 50mm lenses at that setting.
Anyone have any ideas what's going on here?
03-01-2010, 08:13 AM   #7
QuoteOriginally posted by jimH Quote
Generally speaking, most lenses (not withstanding Pentax Ltd's) focal length are not exactly as indicated. A manufacturer's 50mm might actually be 47 while another one might be 53. That could explain part of the discrepancies. And lenses with internal focus will have a longer focal length at close focusing than at infinity. Put those two factors together and you end up with a lot of latitude as to what you call 50mm.
03-01-2010, 08:32 AM   #8
jimH's Avatar
Thanks for the insight Yves and I believe that probably is the case with my two lenses.
03-01-2010, 10:26 AM   #9
Ben_Edict's Avatar
QuoteOriginally posted by octavmandru Quote
Octav
You did a lot of work. But basically your measurements are way too far off, to be useful. You simply cannot use the viewfinder for placing the poles as targets. The only really valid way to achieve repeatable and comparable results is to take real images and measure the negs. Simply leave your camera at a fixed distance from a target, which could be a simple ruler. position the ruler parallel to the film plain and near the center of the field of view. Than you can take test shots with both lenses at different focal settings and measure the real angle of view.
Why am I so outspoken? Because while the Pentax A 70-200/4 is a fine lens, it is certainly nowhere near 300mm in focal length. A simple look through the zoom and a 300mm prime will confirm that, the 300mm lens offering a much smaller angle of view! So, if your measurements lead you to showing 300mm fl for the Pentax A zoom, there must be something fundamentaly flawed with your way of mesuring this.
Ben
03-01-2010, 10:54 AM   #10
Dear Ben,
My measurements were nowhere even close to difficult. Lightstands are perfectly vertical and easy to move since they are voice activated.
The viewfinder is a constant in the equation.
My measurements/calculations could be flawed, but how?
For confirmation of my calculations I used this:
Lens Focal Length and Field of View
What I am certain about is this: the horizontal FOV on Pentax is close to half of the Tamron's at the same setting.
Octav
03-01-2010, 12:56 PM   #11
Ben_Edict's Avatar
Octav
No, that's wrong. The Dimitrov calculator gives the angle of view diagonally(!), whereas you are measuring along the longer side of the image. So your measurement needs to be smaller. It does not indicate a focal length increase.
Ben
03-01-2010, 12:59 PM   #12
Ben_Edict's Avatar
Octav
That would be the conclusion, which I can follow, based on your measurements. But the "translation" into real focal lengthes needs to be more thinking (not meant as criticism, but more meant as a challenge to myself!)
Ben
03-01-2010, 01:54 PM   #13
QuoteOriginally posted by Ben_Edict Quote
Ben
Ok, I was hasty posting B. Dimitrov link... I like this more: Depth of Field & Field of View Calculator Wildframe
Acc. to this, HFOV is 7 dgr. with a 300 mm lens and a FF camera. I've got 8 dgr.
For the theory check this link: Field of view and focal length
Take into account I calculated it first using my method and only after searched for more info. I admit I was a bit crude, but I didn't want to make rocket science out of a simple observation.
The math is very simple. I just wonder how such discrepancies occur.
But at least, according to this: http://www.rmassa.com/specsheets/BOOKLET-200704%2033.pdf you calculate the focal lenght of the lens from the optical centre of the lens called here secondary principal point, so I wasn't wrong in the first place.
Octav
03-01-2010, 03:34 PM   #14
Ben_Edict's Avatar
Octav
The problem is, that we do not know, where the rear nodal point is located in these complex zoom lenses, unless the manufacturer released the data, which I don't know.
At the short distances, which obvíously are unavoidable, to see and measure the decrease in fl at near distances, the the placing of the rear nodal point is critical, as it can amount to app. 10% of the whole object distance and thus influence any subsequent calculations significantly.
Ben
a1, angle, degrees, distance, k-mount, lens, mm, pentax, pentax lens, slr lens, tamron, viewfinder
focal length ewig Troubleshooting and Beginner Help 11 07-23-2010 09:32 PM
K7 is 1.5 x focal length? rdrum76 Pentax DSLR Discussion 18 06-30-2009 08:30 AM
What is Focal Length Ole Photography Articles 2 05-15-2009 12:20 PM
Focal Length ? deludel Photographic Technique 14 01-30-2008 06:58 PM
Focal Length Jimsi777 Pentax SLR Lens Discussion 2 11-09-2007 06:46 PM
All times are GMT -7. The time now is 03:35 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
