Originally posted by Egg Salad Don't know which particular picture you mean but I've found two comparison images that illustrate the differences between F 1.7/50 and A 1.2/50.
I can't see if the focus is the same but it must be close.
The F weirdly seems to exaggerate the sharper portion of the image - the flower (especially distinct on the petals) while the A renders the whole scene with smoother transitions - can be seen on contrasty edges.
F:
Pentax-F 50/1.7 @ f/1.7 photo - Sean Carpenter photos at pbase.com
A:
Pentax-A 50/1.2 @ f/1.8 photo - Sean Carpenter photos at pbase.com
Objective tests aren't even possible - especially not when it's only one person doing the rating. Firstly there is the human factor which allows for a great variety of of testing errors and also if the person diong the test is photography-affine he7she is most likely prejudiced. The larger the testing group the more objective the results get.
The same can be seen here all the time: people logically tend to suggest the lenses they own.
But this is statistics and has nothing to do with this.
Still, can somebody give a description on M42 lenses or provide a link?
I can assure you that I've done the testing objectively as possible, without any prejudices.
as you've mentioned yourself and the test that you saw, it did verify my finding with regards to sharpness of the F1.7 at wide open and the smooth rendering of the f1.2. at f1.8.
I did some independent testings several times. tripod use, with/without lens hood, lighting condition, focusing distance and at varying stops. and I had to redo some shots just to make sure that the initial testings that I've done are consistent with the newer ones. so the margin of error there is lessened to a wide degree and bias is not even a factor. besides, what can I possibly achieve by prejudice? my point here is to only state facts. facts that determined my preference of a lens over the others, of which I tend to use more often because of those facts.
anyway, what I meant by below f2.8, I meant something at lower apertures like f3.2 and onwards. not something f2 and higher. you might had misunderstood me in that area.
so anyway, if there is anyone that had done some testing that had a different or opposite result from what I did, and the results by Sean Carpenter, I would be happy to see it.
