Originally posted by JeffJS
The APS-C sensor is 2/3 of a 35mm frame (23.4 x 15.6 mm), not half..
Sorry to be pedantic -
Actually RioRico was more correct by area....
23.4mm x15.6mm = 379.08 sq mm
Full-Frame is
36mm x 24mm = 864 sq mm
so APS-C is actually 43.875% of a Full-Frame
Just to be sure -
if we took a piece of paper and wanted half the size -
we'd cut it in half......
that is by area,
not by linear (one dimensional/length) measurement -
the linear scale would be the square root of 2.
However in mitigation, focal length coverage is calculated by the ratio to the diagonal of the film/sensor frame and this is linear
- that's where the crop factor comes from.
85mm was a close portrait lens for Full-Frame - since APS-C has a crop factor of 1.5x
- to get the same equivalent focal length one would need about 57mm.
So a cheaper and more common 50mm f/1.4 or f/1.7 lens would probably be more suitable -
which would be a 75mm equivalent in FF.
