03-03-2010, 12:31 PM   #1
Question about "close up lens"
I have a set of questions about close up lens that come with Voigtladander SL II 40/2 Ultron...
1. Can it be use with other lens?
2. Why don't lens manufacturers built the lens with the close up glass piece into it in the first place? Why make it removable?
just curious.
03-03-2010, 03:32 PM   #2
Marc Sabatella's Avatar
1) Presumably with any other lens that has such a small filter size (which is to say, almost no other lens :-). but there are of course lots of other close up lenses on the market in other sizes. Most are junk; you want one that is a mutli-element "achromatic" design (and multi-element does *not* mean, those sets of three *separate* lenses you often see).
2) Because with the closeup lens mounted, it can't focus to infinity. Close up lenses are like reading glasses.
03-03-2010, 08:49 PM   #3
Just1MoreDave's Avatar
One lens that comes with a similar accessory is the Cosina/Vivitar/Phoenix/Pentax 100mm f3.5 macro. They call it a "matched macro adapter". It allows the lens to do 1:1 magnification.
03-03-2010, 09:00 PM   #4
Igilligan
Guest
The reason they don't 'build it in' is that it limits focusing distance.... no infinity focus. Only close ups.
So you use the close up filters when you are close up focusing only.
03-04-2010, 09:17 PM   #5
Thank you all for your response.
03-04-2010, 10:48 PM   #6
RioRico's Avatar
Raynox close-up lenses, of the achromatic type Marc mentions, are highly regarded. I and a number of members of this forum use the Raynox DCR-250. Other models with different magnification / close-up characteristics are available, depending on your needs. A 'universal' front thread adapter is included with each Raynox lens, but it will not mount on threads as small as your Ultron. You will also need an inexpensive step-up adapter, 40mm to at least 49mm.
close, k-mount, lens, pentax lens, slr lens
Do custom "artistic" or even "funny" lens caps evenexist? lovemehate Pentax SLR Lens Discussion 35 02-10-2016 09:10 AM
K-mount Experts: How to convert a "KAF2" lens to "KF"? panoguy Pentax SLR Lens Discussion 24 07-08-2010 05:20 PM
Stupid question - what is meant by a "Limited lens" Oggy Pentax SLR Lens Discussion 30 12-17-2009 09:44 PM
Old "Image" Brand Lens question bbpa103 Pentax SLR Lens Discussion 2 12-19-2008 08:09 AM
"Hunger for a DA*50-135?" or "The DA*50-135 as a bird lens!" or "Iron age birds?" Douglas_of_Sweden Post Your Photos! 4 08-13-2008 06:09 AM
All times are GMT -7. The time now is 11:24 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
