03-03-2010, 01:02 PM   #1
tips on changing lenses
So finally I got me some of them Limiteds, and now find myself changing lenses more often. With the previous Tamron zoom almost never did this. When I did, I took some sweet time putting the camera on a clean desk and making sure everything has a place.
Now when I do it in the field, I try to follow a sequence. The room must be there for the lens going off to land safely with the back end up, and a spare back cap must be ready. That way it won't wait until the back cap is going off the new lens. Fumbling for the red dot may take a moment, I prefer not to let go and rotate the hand, leading to some awkward angles.
Then the new lens is going on, with the back cap going to a dedicated place.
I noticed some folks mention velcro and duct tape, which I can't imagine myself putting on any cameras or lenses, but am curious how folks use them.
Also, a question is, where do you store the front caps when you shoot? Do people use those tethers making them dangle from the lenses?
03-03-2010, 01:20 PM   #2
RioRico's Avatar
My lens changing procedure: Make sure space is available somewhere, even if it's just slinging my Ameribag around in front as I stand. New lens lies near, maybe protruding from bag. Both lenses are capped. Old lens comes off - place lens end down, camera body is mount down. Rear cap comes off new lens, onto old lens. New lens and camera body go horizontal, lens is inserted and locked. Push old lens into bag, zip up, sling bag around, and I'm ready.
Tethers break. My lens front caps go into my front pants pocket.
03-03-2010, 01:25 PM   #3
Ira
QuoteOriginally posted by braver Quote
Pockets. Pockets. Pockets.
03-03-2010, 01:29 PM   #4
Jasvox's Avatar
Sounds pretty tidy, but in real world shooting locations, there is not time to set up your "changing station" per se. I simply have the lens ready I want, tilt the camera facing down, twist the lens off the body, pocket it or rest it someplace, twist on the new lens, use cap from new lens for old lens and voila....done and takes what, 8 seconds?
If you are using prime lenses and plan to be out shooting in many different environments,. just make sure you have a safe, quick procedure for changing lenses on the fly, it's not hard and should be second nature if you plan to always be ready yo use the correct lens for the correct shots.
Jason
03-03-2010, 01:33 PM   #5
Please read this thread and this thread on double lens caps.
03-03-2010, 01:43 PM   #6
Nowhere Matt's Avatar
And don't forget, on all Pentax mount lenses, the red dot is in line with the aperture setting line of the lens. It is sometimes a little easier to find that line above your aperture ring than the red alignment dots of the lens. If an A, F or FA lens is being used and locked in auto aperture, just drive that big A right in there.
03-03-2010, 01:51 PM   #7
I prefer to be standing at the top of an eight story building when changing lenses. This way if I am careless enough to drop the lens at least seeing it's glorious impact will make a decent story.
03-03-2010, 01:57 PM   #8
It's like babies & diapers; you make do with what you got!
QuoteOriginally posted by Jasvox Quote
03-03-2010, 02:02 PM   #9
Here is a thread on changing lenses: Here.
03-04-2010, 02:41 AM   #10
Pentaro's Avatar
A lot of dust accumulates on the cap when I put it in my pants/shirt pockets - and a rocket blower cannot completely clean it. I'm afraid that the pinch mechanism might lose its smoothness sooner than it should. Perhaps I need a cleaner pocket...
03-04-2010, 03:23 AM   #11
LeDave's Avatar
I always use rocket blower whenever I change my lenses, it has become a routine. I blow out the rear element then I blow out the body and quickly re-blow the lens before quickly snapping the lens on.
03-04-2010, 07:24 AM   #12
Changing Lenses:
First, I Hate those Press on rear caps. I have a supply of the aftermarket twist on types (like the older Pentax rear cap) for that reason. The press on types end up on lenses that I resell. With the twisty types, (camera strapped) I remove the cap while holding the lens (one handed operation).
I Remove the lens that's on the camera (back facing any wind). I then remove the rear cap from the replacement lens and transfer it to the take off lens. Then I put the new lens on the camera. Then the old lens goes back in the bag or in a coat pocket if that's how I'm out. That's Prime lenses. If I've gone out with a zoom, it's been for a specific purpose and I don't change them out,
What to do with the Front cap? Shirt pocket. I don't buy shirts without them.
03-04-2010, 07:30 AM   #13
QuoteOriginally posted by Nowhere Matt Quote
You might even have time before impact to get your camera ready for a shot of the glass shattering.. Any takers what to try it and get a picture?? No? Didn't think so...
cap, folks, k-mount, lens, lenses, pentax lens, slr lens
Changing Lenses in the Field jaieger Pentax SLR Lens Discussion 38 07-25-2010 09:23 AM
Landscape Changing Lenses Jimbo Post Your Photos! 13 12-10-2009 01:36 PM
Changing Lenses Rondec Troubleshooting and Beginner Help 32 05-07-2009 02:12 PM
Changing Lenses Fl_Gulfer Pentax Film SLR Discussion 13 12-24-2008 08:55 AM
Tips using big mirror lenses like C5 barondla Pentax SLR Lens Discussion 29 07-04-2008 12:53 PM
All times are GMT -7. The time now is 12:09 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
