Originally posted by Pornflake I'm also considering this two lenses, if someone who owns any of them give their opinion would be good.
thanks
I own the 17-70 and like it a lot. the only thing I would change would be to make it 2.8 through out the range, but then again that would push the price up considerably.
the bohken (sp?) is smooth but not buttery smooth like my pentax smc m 50 1.4.
the 17-70 is very sharp, almost too sharp for certain portrait shots (that doesn't bother me though as I PP with photoshop anyways)
The macro is really good for a non dedicated macro lens and the only thing that stops you from getting closer to the subject is usually the shadow from the lens.
The lens is a bit big, comparing it to a prime lens.
I would say if you really need the 2.8 throughout, then go for the 18-50mm (and can spare the extra price)
If not, I would go with the 17-70mm (remember from 17-50mm the range is between 2.8 and 3.5, not a huge difference from the 18-50mm)
I think you would be happy either way...
let us know how you make out
good luck
cheers
randy
