HI!
As you can see in my sig I have a super takumar 50 1:1.4 but there's, was, only one problem with it. Unmounting it and using k mount lens is/was a pita.
After unscrewing the lens the adapter would still remain in the camera. I had to hold one small pin and then unscrew it.
Well I removed the pin, and lost the small screw doh
. I tried the lens and now I can just mount and unmount the lens as a normal k mount lens as the adapter, without the pin, will remain screwed on the lens.
Is that small lever really needed? I tried the lens, changing the aperture and focusing and the lens seems to be held on the camera pretty tightly, i.e. it won't accidentally unmount while playing with the camera.
Thanks
Deni
