03-10-2010, 10:51 AM   #1
the FA 31mm rattles a bit
Got a new FA 31mm, amazing sharpness! One thing I'm not sure about is, it rattles ever so slightly if you try to wag it by the hood. Also, when pixel-peeping, looks like the very edges are just a bit softer than the center, I guess it would be expected of any lens?
03-10-2010, 10:58 AM   #2
henryjing's Avatar
I've never used it and cannot answer your question.
But nice lens, always my dream lens.
Congratulations!
03-10-2010, 11:11 AM   #3
Just1MoreDave's Avatar
QuoteOriginally posted by braver Quote
I see how you came by your forum name. I would not be "wagging" an FA31 by the hood.
In general, stuff has to move inside a lens, some of it has to move fast, so parts can't be fitted tightly enough to not rattle a little.
03-10-2010, 12:00 PM   #4
Wheatfield's Avatar
We need a sticky.
Lenses rattle.
It's because they have moving parts that need enough slack in them to move.
Take away the rattle, and you've taken away the ability for things to move.
Go out and take some pictures, you spend far too much time posting about non problems that you think you've found.
03-10-2010, 12:16 PM   #5
Pentaxor's Avatar
damn snakes. they are everywhere.
03-10-2010, 01:31 PM   #6
farfisa's Avatar
Mine doesn't rattle at all. Have you tried banging it on something to see if it goes away?
Okay the last part was a joke, but mine really doesn't rattle at all.
But the edges are a bit softer than the corners, and yes, that's true of most lenses, though resolution is more even in pancake lenses like the DA40 and DA70, and also some macro lenses, which are optimized for copying and stuff.
03-10-2010, 02:53 PM   #7
I have one and it does rattle slightly. Still is stark as a tack.
03-10-2010, 03:00 PM   #8
Mine does, too. I exchanged one because the rattle was excessive. Even slightly rocking the lens caused it to make a "tick-tock" sound. It had arrived with a smashed corner on the original box (not the shipping box) and it was evident it was dropped at some point. My second arrived perfect, but still exhibits a slight rattle which I figure is normal.
03-10-2010, 07:57 PM   #9
QuoteOriginally posted by Glarus Quote
Ah! Rocking -- here's the word I was looking for... I don't know if it qualifies as tick-tock -- I feel the tick-tock, but the sound is very soft, rocking sound. I'd say the movement is 0.1mm or less. It's tack sharp. I've read that due to its design, the focus ring is not dampened. Perhaps it should rock a bit also...
03-10-2010, 11:19 PM   #10
wlachan's Avatar
Mine is the same as yours, and I have come across 3 others samples in the past, all the same except some more obvious, some not. It has to do with the way the inner moving parts are designed (different from all other Limited lenses). If it's sharp, nothing to worry.
31mm, bit, fa, fa 31mm, k-mount, pentax lens, slr lens
Windows 7 64 bit & CS4 64 bit ? holdgaj Digital Processing, Software, and Printing 2 10-20-2009 06:12 AM
People a bit playfull, just a bit devisor Post Your Photos! 4 10-15-2009 12:25 AM
24 bit or 48 bit scanning photolady95 Digital Processing, Software, and Printing 3 05-29-2009 08:14 AM
12-bit, 14-bit and 48-bit capture Clarkey Troubleshooting and Beginner Help 1 02-19-2009 09:16 PM
what is the difference bwt exporting to 8-bit or 16-bit tiffs? rdrum76 Photographic Technique 3 01-22-2009 01:51 PM
All times are GMT -7. The time now is 04:43 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
