Quote: Do I change this back when I switch back to the 18-50 kit lens?
No, just leave it like that.
Quote: I forgot to do this part but the camera worked. What did I miss out on by forgetting this step?
Was your photo properly metered? If yes, you didn't miss anything. If not, you missed a properly metered photo, not too bright/not too dark.
On my k100d, when I use the super takumar 50/1.4 I've found that the camera will meter, almost properly, even if I leave the dial to Tv or Av. Don't know why it hapens but I can't complain, can I
Quote: I never saw any kind of prompt to tell me to plug in a lens (actually, the lens was already on the camera. Was this a problem?).
No problem. Next time you turn on the camera with a full manual lens attached to it, you'll see a screen showing numbers. Those numbers show the focal length that the SR has to be adjusted for, i.e. with your 50/1.7 lens the focal length is 50mm, so you have to choose 50.
That menu will show up every time you turn on the camera and a full manual lens is attached to the camera.
Quote: 4)Frame and focus your shot, then briefly press the "green" button.
I forgot this part, too. I think I'm going to have to try this again when I have more time (and am more awake).
Well, you did focus manually, did you? You have to if you want a focused image
. When you're in focus, the camera will let you know. Also if you set your camera to af when using a manual lens, the camera will not fire until you've got proper focus.
As far as I know the camera can't do "step down metering" with k and m lenses. Only A lenses and newer can.
If you want the camera to properly meter with a fully manual lens (k/m/m42 lens):
1. you keep wide aperture till you achieve focus (easier wide open since the viewfinder is brighter. On your m 50/1.7, the widest aperture is f/1.7
2. Once you got, focus, you step down (set the aperture you want), lets say f/4. You'll see the view in the viewfinder will become dimmer. Then you have the camera meter for you, or you can do it yourself if you have the dial set to M. Though as I said the k100d I have continuously meters if I have the dial set to Tv/Av. If I want to be sure I press AE-L (set it in the menu).
Quote: Here's another question for you. The manual said to turn off Anti-Shake when using a tripod. I tried it both ways and it seems like leaving it on was better. Why does the manual suggest turning it off?
I've used the camera with a tripod, or resting somewhere and forgot to turn off the SR, yet I got a sharp photo. Don't know why is that. People say that the SR will get confused as it always tries to compensate for the movement when we press the shutter, thus photos might turn out with shake blur.
