Originally posted by GridUser I'm not sure what you mean by using spot metering in "stop-down mode". I mean, you explained HOW to do it, I just don't know why to do it or what it does.
As far as having an "A" on the lenses. They are old and don't have any markings other than for aperture and focusing. I guess I'll just fiddle around with them for a while and see. I get the camera this Wednesday (FedEx permitting) but only have a few days to get it right before I go to Oshkosh for the big airshow. I need to have it figured out by then, so I may let the guy who's going with me drive while I read the manual and experiment.
Hi Griduser, here's a quick step by step and a few explanations
To shoot with manual lenses (I'll use your K 1.7 as an example)
1) After mounting the lens, go to the custom menu and set the "use aperture ring" to "allowed" After you do this once you can forget this step. The camera will remember.
2) Change the dial mode to M (for manual)
EDIT 2a) Almost forgot, when prompted plug in 50mm so your camera knows the size of the lens for the anti shake. (don't have anti shake so I forget this one alot)
3) You will have a choice of two metering modes; center weighted and spot. Spot means just that, where ever your little red square is on the grid that is the spot the camera will read to get the light settings, center weighted means it takes an average but gives much more weight to the light in the center of the viewfinder. I don't own a K10D, but I know the DS defaults to center weighted.
4)Frame and focus your shot, then briefly press the "green" button. If the K10D is like the DS you will hear the noises of the mirror flipping up and camera metering the light and stopping down the lens, this is what is called stop down mode
5)press the shutter and take your shot.
All of this sounds a lot more complicated than it actually is. I have a whole bunch of manual lenses and can shoot almost as quickly with them as with the newest and fastest lenses I own. Pretty much it's frame/focus press button, press shutter. It really is that quick
NaCl(hope that helps)H2O
