03-13-2010, 06:21 PM   #1
Da 18-55 /11
My friend just purchased a new Kx the kit lens is a mark 2 version has different colour anodizing on it , thats the only difference I can see.
Is there any optical difference with this lens?
03-13-2010, 06:28 PM   #2
Blue's Avatar
Exactly which version do you have? The original version of this lens has been out of production for a while and it was optically different from the II, the WR and DAL currently in production. In addition the II and WR have the SP coating.
03-13-2010, 07:00 PM   #3
I have the original on a black Kx my friend has the mark 2 came withe the red body yellow hand grip version of the Kx
03-13-2010, 07:26 PM   #4
So wedgetail, is the version you have mounted on your K-x the plain 18-55 you got from somewhere else and mounted on your camera, or the DAL version of the 18-55 (plastic mount) that came with the K-x? (DAL is written on the side of the lens and the front of the lens).
If it's the DAL 18-55, it's optically identical to the 18-55 II - ie essentially the same lens.
03-13-2010, 07:28 PM   #5
Blue's Avatar
QuoteOriginally posted by wedgetail Quote
Production on the DA 18-55/3.5-5.6 AL ceased in early 2008 and was replaced by the AL II. The WR and DAL have the same 11/8 elements/groups. The earlier one has 12/9. The WR also has the SP coating.
Did you get yours used after you got the K-x because it didn't come with the K-x unless someone swapped them. BTW, the Kx is a film body from the late 70s. The dSLR is K-x. Similar think with the Km & K-m.
Edit: There is a comparison of the various Pentax short zoom K-mount lenses here including the 4 discussed in this thread.
http://kmp.bdimitrov.de/lenses/zooms/short/index.html
03-13-2010, 07:48 PM   #6
Pentax Zoom Lenses with Short Focal Lengths
My dslr kx was bought from Office works here in Adelaide South Australia came with the DAL 18-55 My friends is DA 18-55 mark 2.
Mine was purchase dec 2009.
03-13-2010, 07:54 PM   #7
Nick Siebers's Avatar
Should be optically the same, then.
k-mount, lens, pentax lens, slr lens
All times are GMT -7. The time now is 09:15 AM. | See also: NikonForums.com, part of our network of photo forums!
