03-14-2010, 11:45 AM   #1
Manual Focal Point adjustment- K20D
Okay i have spent hours on here looking for the answer, I found the pictorial guide to using manual lenses with the K10D. However, if I try using any of my older lenses (third-party) that are not Pentax A1, I cannot adjust the focal point and end up the dreaded blinking "F--".
The section of the menu that lists the "insert Focal Length" is dimmed out and will not allow me to select it. I have had this camera for about 6 months and otherwise I am very happy with it. The main purpose for selecting this one, was the ability to use all these older lenses.
Thank you.
03-14-2010, 11:50 AM   #2
Wait, I'm confused about your problem. You're saying that you already changed the Custom Settings #23 to Using Aperture Ring permitted, and can use the MF lens, but when changing focus points it gives you error?
03-14-2010, 11:52 AM   #3
Welcome to to the forum.
You have to turn on "using aperture ring" in the custom settings. Here is a sticky from the beginners area to help you on it.
https://www.pentaxforums.com/forums/pentax-beginners-corner-q/59272-shooting-...x-dslrs-f.html
03-14-2010, 11:53 AM   #4
darrenleow's Avatar
QuoteOriginally posted by heaven72501 Quote
Thank you.
Custom Setting #36: "Using aperture ring", set that to 2 (Permitted). Also, Custom Setting #26: "Green button in TAv & M", set that to 2 (Tv shift). You should be able to use the manual lenses in green button stop-down metering.
03-14-2010, 12:30 PM   #5
Yes I have the aperture ring set to permitted. The only one of my manual lenses it will allow me to snap pictures with is:
PENTAX-A 1:2 5OMM
The following are all my camera's and lenses. The other manual lenses will not let me shoot.
PENTAX K20D
PENTAX-DA1:35-5.6, 18-55MM AL II
PENTAX K1000 (3 OF THESE)
Manual Lenses:
Takumar (bayonet) 1:2.5 135MM Albinar-ADG TELE-CONVERTER 2X
Albinar-ADG 1:2.8 MACRO FOCUS --28MM-50MM
PENTAX-A 1:2 5OMM
Albinar-ADG 80-200MM 1:39 -- (55MM) MACRO ZOOM
03-14-2010, 01:06 PM   #6
Okay, I'm stupid. I forgot to reset it back to MF and had it on the wrong setting after letting my daughter use it. I didn't realize I had to reset the aperture ring for each of my lenses. Thank you all!
k-mount, lenses, pentax lens, slr lens
Focal plane adjustment for K1000 Simian Summit Pentax Film SLR Discussion 3 03-11-2010 06:45 AM
multi-point (11, 16, whatever) focal system—WHY?? WMBP Pentax DSLR Discussion 15 03-02-2010 10:51 AM
Setting up focal point for manual lenses. consider crop factor? D4rknezz Troubleshooting and Beginner Help 7 09-23-2009 01:00 PM
Manual lenses and focus adjustment max889 Pentax SLR Lens Discussion 3 09-07-2009 11:48 AM
manual lens focal length nodretep Pentax DSLR Discussion 3 03-11-2009 04:16 AM
All times are GMT -7. The time now is 06:13 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
