Originally posted by ll_coffee_lP Probably not what you want to hear, but shooting landscapes at f/8-f/16 you already have the ideal lenses in the two kit lenses (unless you wanted to upgrade slightly to DA 16-45mm and DA 55-300mm). Stopped down that far you are not likely to notice a significant difference in with the primes and your lenses now in your shots.
Just some thoughts. Doesn't seem to make much sense to purchase DA35 or DA40 for what you are needing/wanting to shoot with.
c[_]
I'm going to have to agree with coffee_IP here -- the 18-55mm kit lens also focuses really really close (basically a 1:3 macro), probably as close as you'll ever need, going by your original post.
Having said that, I had both the 40 and the 35 and only used the 35 for macro. I loved the thought of essentially not having a minimum focus distance. But the 35mm focal length wasn't right for me at all--I never wanted to stay there. Strangely enough, I'm happy using a 40 all day though.
I say if you really want to buy a prime (and hey, nobody here can really blame you
), then stick your kit lens at 35 for a bit, then at 40 for a bit and decide which is right for you. Either one of these will serve you well!
