03-29-2010, 06:56 PM   #16
QuoteOriginally posted by Miserere Quote
The Tamron Also focuses a bit closer if I remember correctly.
It's only an issue in high contrast situations, like tree branches against a grey sky. If you stay away from that type of scenes you won't have any problems.
These are all good to know. Thanks again!
03-29-2010, 07:59 PM   #17
QuoteOriginally posted by cyberjunkie Quote
I was looking for a fast "normal" zoom when i found exactly this Tokina for sale.
The vendor says that the Ricoh pin of the lens is safe, with AF digital bodies, as far as you remind yourself to put the iris ring in "A" position before mounting/removing the lens.
I didn't notice it first hand, but from the pictures i see that the ricoh pin looks like a ball-head one. From the infos i got online, i understand that even if the lens gets stuck, operating the MF-AF switch while turning the lens would allow to solve the problem.
Are the two assumptions true?
Any other relevant info?
This lens should serve your intended purpose well.
Yes, the Ricoh "pin" on this lens is a actually a small metal ball. It is also very lightly sprung - I don't see how it could get stuck in the AF recess. At least, mine has never given me problems on my K20D.
If you don't mind me asking, what is the seller asking for this lens?
Also, don't forget to post some pics if/when you get yours.
04-25-2010, 07:50 PM   #18
Here are some test shots at 70mm and f2.8 - they look quite sharp to me. Lateral CA is fairly well-controlled (better than I expected). What I did notice was a little bit of bokeh CA - green haloing behind the plane of focus, purple haloing in front, in high contrast areas. However, this was only apparent when viewing at 100% and I have seem worse from a few FA* lenses.
Sample #1 (link to full-sized version here):
100% crop:
Sample #2 (link to full-sized version here)
100% crop:
These were all converted from PEF using PPL. Default settings were used, except for sharpness +1.
I should add a disclaimer that my MF skills are not that great, though these should be fairly well focussed as I took several shots and choose the best one.
In addition, I was also using a low-quality UV filter which may have affected the contrast, as I do not have a lens cap for this lens.
at-x, f2.8 manual focus, focus, k-mount, length, lens, pentax lens, photos, post, ricoh, slr lens
For Sale - Sold: Tokina 400mm f5.6 RMC manual focus lens Blue Sold Items 7 06-17-2010 09:28 PM
For Sale - Sold: Tokina AT-X 300mm f2.8 KA mount Manual Focus Lens gscara Sold Items 9 05-22-2009 09:18 AM
For Sale - Sold: Tokina AT-X 80-200mm F2.8 (manual focus) Gooshin Sold Items 35 03-05-2009 10:08 PM
FYI - Tokina 80-200/f2.8 manual focus kjao General Talk 2 10-19-2007 08:07 AM
Tokina 80-200/f2.8 manual focus lens kjao Pentax SLR Lens Discussion 4 10-05-2007 04:51 PM
All times are GMT -7. The time now is 09:03 PM. | See also: NikonForums.com, part of our network of photo forums!
