03-16-2010, 06:54 PM   #16
GregK8's Avatar
Measurrements
I did a little experimenting tonight, so for anyone interested, here are my results.
I used the Raynox DCR-150 on the DA 18-55 AL II kit lens and the DA 55-300 ED. I used my K20D body, aperture set to F8 and the focus ring set to infinity.
DA 18-55 AL II @ 18mm
Unusable due to vignetting, not a practical setting so I aborted this measurement
DA 18-55 AL II @ 35mm - Ruler visible 5.5"
Measured Values: Working Distance (WD) 207mm, Magnification Ratio (MR) 5.5:1
Calculated Values: WD 208, MR 5.95:1
DA 18-55 AL II @ 55mm - Ruler visible 3 5/8"
Measured Values: WD 208mm, MR 3.625:1
Calculated values: WD 208mm, MR 3.788:1
DA 55-300 ED @ 55mm - Ruler visible 3 9/16"
Measured Values: WD 208mm, MR 3.5625:1
DA 55-300 ED @ 100mm - Ruler visible 2"
Measured Values: WD 208mm, MR 2:1
Calculated values: WD 208mm, MR 2.1:1
DA 55-300 ED @ 200mm - Ruler visible 1"
Measured Values: WD 208mm, MR 1:1
Calculated values: WD 208mm, MR 1:1
DA 55-300 ED @ 300mm - Ruler visible 11/16"
Measured Values: WD 208mm, MR .6875:1
Calculated values: WD 208mm, MR .69:1
There you go. I didn't get out my calipers, so there are some minor measurement errors and I suspect that most of the differences are due to the error caused by the sensor in the K20D being slightly smaller than an inch.
So the conclusion? To get a similar result to a 100mm 1:1 lens, the DCR-150 on a 200mm lens.
03-16-2010, 07:12 PM   #17
Pentaxor's Avatar
QuoteOriginally posted by GregK8 Quote
DA 55-300 ED @ 55mm
you are just about right on the 200mm 1:1 ratio.
03-16-2010, 07:30 PM   #18
GregK8's Avatar
A Few Examples
And just to completely put a cherry on the top of this thread, here are a few shots taken with the Raynox on the 55-300mm at the Botanical Gardens here in Buffalo.
Without the diopter
With the diopter
03-16-2010, 10:17 PM   #19
Physics is beautiful....
100mm, diopter, distance, focus, k-mount, length, lens, magnification, pentax lens, question, ratio, slr lens
Magnification Question: Reversed 50mm vs. Raynox 250 twokatmew Troubleshooting and Beginner Help 2 07-18-2010 04:15 PM
Question on Magnification Ratios jaieger Troubleshooting and Beginner Help 8 07-13-2010 09:45 AM
New High Ratio Zoom RuiC Pentax News and Rumors 51 06-27-2010 08:24 PM
What's your keeper ratio? jct us101 Pentax DSLR Discussion 48 03-17-2010 01:56 PM
Magnification ratio in macro photography ntx Pentax SLR Lens Discussion 7 08-19-2009 02:22 PM
All times are GMT -7. The time now is 03:36 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
