03-16-2010, 05:23 AM   #1
GregK8's Avatar
Magcro Magnification Ratio Question
For those of you that like the short version, I'll state the question first. How would one calculate the magnification ratio of a non-macro zoom lens with a diopter attachment at any given focal length?
I have been experimenting with macro photography recently by using a Raynox DCR-150 on my DA 55-300 Zoom It is a diopter of 4.8 and seems to make some pretty good images.
I've been considering stepping up and buying one of the various prime macro lenses, either the Tamron AF90 or the Pentax D FA 100mm, both of which has a 1:1 ratio and a minimum focus distance of about 30cm.
All of this thinking brought a question to mind and I haven't been able to find any info about it, so I thought I'd throw it out here for some discussion.
I have read that you can calculate the minimum focus distance of a lens with a diopter adjustment by dividing 100mm by the diopter value. This seems to be the case for the Raynox because the diopter on that is 4.8 and everything wants to be at around 20cm to be in focus. So the question is how would one calculate the magnification ratio of the lens at each focal length of the zoom, say at 100mm, 200mm and 300mm? I suspect it is less than 1:1 especially at the long end, but I'd like to understand how to calculate it.
Someone here has to know, right?
03-16-2010, 07:41 AM   #2
twokatmew's Avatar
The thread "The Raynox Macro Club" has a lot of info on this subject:
Raynox Macro Club link
Newarts in post #91 provides the forumula for calculating closest focus distance:
formula -- post #91
There's more discussion in the posts that follow. IIRC, someone (can't remember who) says the working distance of a 100mm macro lens is less than that of the Raynox 150.
The formula for magnification when a close-up lens of strength D is put in front of a primary lens of focal length F is:
Magnification = F*D
Hope this helps.
03-16-2010, 07:44 AM   #3
twokatmew's Avatar
I forgot to mention....
I've got a DA35.2.8 Macro and really like this lens. But ... to get close to a true 1:1 macro, working distance is practically nil, and I end up blocking light. I've got a DAL50-200 and a Raynox 150, so I'll be playing with that soon, as I definitely need more working distance at times. I believe you get 1:1 at ~140mm with a Raynox 150.
03-16-2010, 07:54 AM   #4
Minimum magnification = (Focal_Length_in_meters) x Diopters.
Example, 85mm lens with 4 diopter close-up filter: .085*4 = 0.34x
Further, Working distance in meters at minimum magnification = 1/diopters
For the Raynox 150 (4.8 diopters) this is about 8.3", 204mm - a nice working distance, a little longer than a 100mm macro lens at 1:1 (200mm).
Old Dave
PS The working distance calculation is for the distance from the optical center of the lens to the subject so is not precise in the real user's world.
03-16-2010, 08:05 AM   #5
twokatmew's Avatar
QuoteOriginally posted by newarts Quote
For those of us using crop sensors, don't we have to take the crop factor into account?
That is, a +10 diopter yields 1:1 at 100mm in 35mm-equivalent format. Thus, on a 1.5x crop sensor, that's just under 70mm. Correct?
03-16-2010, 08:22 AM   #6
QuoteOriginally posted by twokatmew Quote
No. "Magnification" is with respect to the image projected by the lens, not the size of the sensor capturing that image. At a 1:1 magnification the image captured by a 36mm sensor is 36mm wide in object space & the image captured by a 24mm sensor is 24mm wide in object space.
The crop factor is taken into account when you enlarge the sensor image to a constant display size.
Old Dave
03-16-2010, 11:09 AM   #7
Marc Sabatella's Avatar
BTW, while you can caculate the magnification in theory for a lens or combo you don't yet own, if you have the goods in your han, you can make it much simpler. Get out ruler, focus on it as closely as you can. However many inches fit across the viewfinder, that's the magnification. This works because an APS-C sensor is essentially 1 inch wide (slightly less, but close enough).
03-16-2010, 12:05 PM   #8
GregK8's Avatar
Hmmmm, why would the specs for both the tamron @ 90mm and the Pentax D FA @100mm report a working distance of 30-31cm?
03-16-2010, 12:06 PM   #9
GregK8's Avatar
Haha
So simple. It's amazing how one can completely over think things.
03-16-2010, 12:17 PM   #10
GregK8's Avatar
So for the DCR-150 and the 55-300mm zoom, if I want a 1:1 ratio, I can divide 1 by the diopter to get 208mm, which is the exact same number as the working distance.
Interesting how that works. So if I set the focal length of the zoom to 208mm, in theory that should be the same 1:1 ratio as a 100mm D FA.
03-16-2010, 12:24 PM   #11
GregK8's Avatar
QuoteOriginally posted by GregK8 Quote
I'll answer my own question, because they are reporting the minimum focal distance, which I believe is the distance from the focal plane to the object, instead of the working distance, which is the distance between the front of the lens and the object.
03-16-2010, 12:34 PM   #12
GregK8's Avatar
Hope this helps.
Very helpful. I can't believe I missed that thread. I always try to make at least an honest effort at searching before I post a question, but I somehow missed that. It must have been in my results and I just past over it.
My wife does say that I'm not a very good finder. I can stare in the cupboard for an hour looking for a can of coffee that is right in front of my face, which she is only to happy to point out as she comes over and grabs it.
03-16-2010, 12:46 PM   #13
That's correct, and is quoted by lens makers because it is more precise, regardless of lens construction (Internal Focus, Recessed Lens, Hood, etc.)
The equation is:
Minimum_focal_distance=Focal_length(1+M)(1+1/M)
Dave
PS any discrepancy is likely because the effective focal length of a 90mm, internal focus lens (for example), is 90mm when focused at infinity, and can vary at other focusing distances.
03-16-2010, 03:13 PM   #14
twokatmew's Avatar
Thanks for the explanation. I think I'm starting to get it now.
03-16-2010, 03:15 PM   #15
twokatmew's Avatar
I happened upon that thread by accident and have bookmarked it, as it has a wealth of info ... and lots of great photos! I'm glad you started this thread though, because I learned something new. Always a good thing!
100mm, diopter, distance, focus, k-mount, length, lens, magnification, pentax lens, question, ratio, slr lens
Magnification Question: Reversed 50mm vs. Raynox 250 twokatmew Troubleshooting and Beginner Help 2 07-18-2010 04:15 PM
Question on Magnification Ratios jaieger Troubleshooting and Beginner Help 8 07-13-2010 09:45 AM
New High Ratio Zoom RuiC Pentax News and Rumors 51 06-27-2010 08:24 PM
What's your keeper ratio? jct us101 Pentax DSLR Discussion 48 03-17-2010 01:56 PM
Magnification ratio in macro photography ntx Pentax SLR Lens Discussion 7 08-19-2009 02:22 PM
All times are GMT -7. The time now is 08:58 PM. | See also: NikonForums.com, part of our network of photo forums!
