Originally posted by sholtzma Well, I have had the Sigma 50-500mm lens for some years now, and I have appreciated its capabilities. But I find myself using it less, both because of its bulk/weight/length and its image quality (which is good but not superb).
Should I send the lens in to Sigma for adjustment, and hope the IQ problem is more a matter of poor adjustment?
Should I accept that, for long focal length reach, it is as good as I am going to get, unless I win the lottery and can put $5000-10,000 into a 400mm f2.8 or 600mm f4?
Should I sell it and use the money to pick up another (better) kind of long focal length lens? If so, what? the Sigma 100-300 f4?
Any help appreciated. I feel stuck.
Obviously the choice is yours, but I will freely distribute some thoughts:
If you need the reach of the Bigma (app. 500mm fl), you would need to add a tc to the 100-300/4, which after all will degrade its otherwise superb IQ and also will make it similarily slow as the Bigma is. I am not sure, this will offer any advantage for you.
If you feel disappointed with the IQ of the Bigma, I can hardly imagine, that the IQ simply "degraded" over time, unless it had a fall or other misfortune. So, assuming the lens is fine, your gained experience and higher expectations, that come with experience, may simply have reached the limits of what the Bigma can deliever. In that case, I would suggest you should forego zooms and go into the prime lens direction. (I won't rule out, you got a sub-optimal copy, though.)
The Pentax DA 300/4 has a very good reputation and can be used with the Tamron 1.4x tc with excellent results, as many, many example images on this site proof. Also the Sigma 300/2.8 would be a possibllity, as it matches with the two Sigma tcs to give you a very versatile combination (300/2.8 - 420/4 – 600/5.6). I personally love my 300/2.8 (though not a Siggi, but an ancient Tamron), but still use the Bigma more often…
Something in the middle would be a 400/5.6 lens. From time to time you may find a Pentax FA version on ebay (2,500 USD or so) or (if you are willing to manually focus) a Pentax smc-A would also fullfill the bill in terms of IQ for much less money (around 500-700 USD). I have the A-version and it is a very fine and capable lens, which I find even sharper than the praised A* 300/4, despite its lacking of the *-denomination.
Ben
