I received the FA77 this morning, played a bit with it on K7... looks like a great lens. First impressions lead me to believe it's as good as the Minolta 85G, but I need to spend a few more days with it before I can pass judgment on that
Anyway... I've got a couple of (probably silly) questions:
Is there a way to lock the hood in the retracted position? Whenever I try to pull the front cap off (it sits pretty firm), the hood extends
Or maybe the cap will loosen up after extensive use?
Is it normal for manual focusing to be active only when the lever on the camera is set to MF? In the custom menu, I've enabled 'Cancel AF' for the AF button, when I press it MF is displayed in the viewfinder, however, the screwdrive doesn't disengage
If I switch from AF-S to MF using the lever on the K7, the screwdrive is retracted and I can turn the focusing ring freely (although I can hear clicks as I turn it, but I assume that's normal). I only have two other lenses to compare to: DA15 and the 18-55 kit; with these two, turning the focusing ring gives no resistance, regardless of the shooting mode (AF-S, AF-C, MF).
Thank you!
Oh, there's one thing I forgot to mention: I bought it from BHPhoto, on their website it's marketed as 'made in Japan', but there's a big engraving on the lens stating 'assembled in Vietnam'; it doesn't bother me that it's not a Japan-made lens, but I guess BH should be more careful what they write on web pages
