07-10-2007, 02:27 PM   #1
Match 11: SMC Takumar 1:1.4 50mm vs. Sears Auto 1:1.4 f=55mm
The Normal Lens Shootout is getting down to the final matches. (Whew!)
This one pits a relatively generic 55mm against one of my most-used lenses. Check it out here!
And as usual, a picture from the match:
Thanks for looking!
--Sean
07-10-2007, 04:13 PM   #2
Once again a great work done. No surprise here of course.
It is facinating that the differences between the lenses (thinking of the whole shootout now) really aren't that big.
One question: In match 3 (M50/2 vs FA50/1.4) you mention the problem with axial CA and color fringing at high contrast areas. Then in match 10 (where again the FA50/1.4 is involved) it is mentioned again.
I haven't seen any other comments on this. I may have missed them somehow of course, but I wonder if you, very understandable, gets a little tired of this intensive test shooting. Or is it that CA hasn't been a grave problem in any other matches?
Thanks again!!
07-10-2007, 04:26 PM   #3
QuoteOriginally posted by Jonas B Quote
Thanks again!!
Thank you, Jonas.
I agree that the lenses are not that far apart in totality. Granted, 11 of the lenses are made by the same manufacturer, so this should not be too surprising. I don't suppose there is a hair's width between the SMC Takumar 50/1.4 and the SMC Pentax-FA 50/1.4.
As for some of the problems (and strengths) mentioned in the first matches, I tried not to repeat the same thoughts unless they were particularly relevant. I write this with my audience being the same 14 people that have read every one!
07-10-2007, 06:33 PM   #4
QuoteOriginally posted by carpents Quote
-snip-
14 only? Well, don't you think some of us need facts repeated? But ok, not particularly relevant - that i can buy.
regards,
07-10-2007, 11:15 PM   #5
Now, I feel special! I must be one of only 14 in the world who've read all of these. Evem though I'm not a technical type, nor a pixel-peeper, I think they're really interesting and illuminating. I just don't want to look that closely at my own pictures :).
07-11-2007, 05:43 AM   #6
roentarre's Avatar
I found every sample shot you took artistic in deed. They are not just "testing" pics. Some of the shots had the bokeh just so dreamingly beautiful.
I had seen some people posting shots of Sear 55mm f1.4 before and their photos are no where near as neat and sharp as yours!
I cannot wait to see the end of this match!
07-12-2007, 09:20 PM   #7
anthropas's Avatar
Hi Carpents,
As I posted elsewhere, I just bought a brand new K10D body and am looking for a good portrait lens for baby pictures for my wife and I's first child (Due Thanksgiving). After reading your reviews and seeing the pictures, I'm thinking it might be a fun way for me to get used to the K10D over the next few months to use one of these manual fast 50's. However, I'm not good on my Pentax mount history and don't know what adaptors are needed for various lenses. Could you refer me to what adaptor/equipment one would need to mount some of these lenses your testing and to use them properly on the K10D?
Thanks!
07-13-2007, 12:12 AM   #8
Any k mount lens doesn't need an adapter to be used on the k10d, or any pentax dslr for that matter.
If you have m42 screw mount lenses, than you need a m42 to k mount adapter. There's a pentax made one and several others made by oems. I've read that the pentax one is the one to get as the other adapters often have problems focusing to infinity.
07-13-2007, 04:50 AM   #9
QuoteOriginally posted by betsypdx Quote
You are special, Betsy!
QuoteOriginally posted by roentarre Quote
Hi James! I've seen some other impressive work with this lens and its clones. Check out this Pbase gallery by dazedgonebye for some great shots with it.
(Thanks for the comments, too.)
QuoteOriginally posted by anthropas Quote
Hi Carpents,
Hi Anthro!
Like Deni replied, you can fit any Pentax bayonet on your camera without adapters. Those are from the following series:
SMC Pentax
SMC Pentax-M
SMC Pentax-A
There are also a couple "Takumar (Bayonet)" [Note: They say the word 'Bayonet' on them] lenses out there in 28mm and 135mm that are the same thing as the SMC Pentax version but without the Super-Multi-Coatings.
Once you get into M42 (aka screw mount, or Pentax screw mount) your options open up considerably. IMO the SMC Takumar or Super-Multi-Coated Takumar series gets you a lens that is 99.9% as good as a modern counterpart. There are also great M42 lenses out there by many other producers; Olympus once made great M42 lenses, Zeiss, Pentacon, Mamiya/Sekor, Soligor and many others as well. Mounting them is easy, you can find M42-to-Pentax K adapters at most used outlets, just make sure they don't have a wide flange on them or else you won't be able to focus to infinity. A quick search should turn up some results for you. (Yes, the 'real' Pentax version works great, it is built to the highest standard of all my adapters.)
As for capturing a new baby...I think a fast 50 is perfect. It gets you close but not too close. You'll have to get used to the focusing with these fast lenses, as the supplied focus screen isn't as good as on a real manual focus camera. Some people can't do it and dump their manual lenses. I'm still waiting for a true manual focus screen from Pentax...
07-13-2007, 06:08 AM   #10
I'm rooting for the FA 50mm f/1.4 (or A f/1.7) Because they are the only 50s I have....
07-13-2007, 09:24 AM   #11
Thanks Sean, as one of the "gang of 14", I appreciate all the work that has gone into this series. And, like James, I truely enjoy reading the "shootouts" because of all the beautiful photography involved. So much more fun than looking at brick walls or mesh screens.
NaCl(I think the "gang of 14" might actually be a "gang of 140" )H2O
07-13-2007, 10:17 AM   #12
QuoteOriginally posted by egordon99 Quote
Ahhh...but what if the reviewer doesn't use autofocus? Hmmm....
QuoteOriginally posted by NaClH2O Quote
LOL, it was of course just a little bit of self-deprecating humor. I've gotten comments from my tinkering idol, Pete Ganzel, so in addition to my friends from here I'm more than pleased with the response so far.
I have a feeling that the A50/1.2 vs. the F50/1.7 will garner quite a bit of interest. It should be ready this weekend...stay tuned!
k-mount, match, pentax lens, slr lens
For Sale - Sold: K100D + 18-55mm; 50-200mm; FA 50mm; Sears 135mm macro; Super-Takumar 50/1.4 (C kveldalf Sold Items 4 09-07-2010 10:13 PM
SMC Takumar 55mm 1.8 vs Smc Pentax M 50mm 1.4 sznajder Pentax SLR Lens Discussion 3 12-16-2009 10:53 PM
Sears Auto 1:1.4 55mm vs. Nikkor-S Auto 1:1.4 50mm carpents Pentax SLR Lens Discussion 8 06-28-2007 03:29 AM
SMC Pentax-F 1:1.7 50mm vs. SMC Takumar 1:2 55mm carpents Pentax SLR Lens Discussion 6 06-18-2007 04:44 AM
For Sale - Sold: Pentax SMC-M 50mm f2 & Sears "Auto" MC 28mm f2.8 inneyeseakay Sold Items 1 01-29-2007 12:23 PM
All times are GMT -7. The time now is 08:43 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
