Originally posted by audiobomber My suggestion is don't worry about it. You have two lenses that cover portrait range already, and I don't see much in nature/landscape that is too wide for 100mm and too narrow for 45. A landscape that needs some in-between focal length can be cropped from a 45mm photo. At least try the three-lens setup for a while after you get the 100-300. (But that's not how our minds work is it? We want more lenses.)
I hear you, although I do tend to find quite a lot of interest in the 45-70 range. I'd be looking to replace the 16-45 with a 17-70 and then not worry about the remaining gap. I'd be especially likely to do this if I had *nothing* between 45 and 100 for use in situations other than hiking - that's the best range for portraits and the like. If you're not seriously concerned about portraits, no nee for that gap to be covered with something fast, but still, I'd want something in there, if just a matter of holding on to the 55-300.
