Originally posted by jpzk The title may seem a bit confusing:
I own a beautiful Carl-Zeiss T*Planar 85/1.4 ZK lens which I use, not often enough, for portraiture and some outdoors activities. It is manual focus but that is not an issue.
I want to know what you folks out there use the 77mm Ltd for.
Would it be worth to "replace" an 85/1.4 with a 77mm Ltd? I say "replace" only because I have no intention of selling the Zeiss lens ....
Would the focal length difference (12mm) make a big impact on the possibilities?
Trying to figure out how the 77mm would compare to a 85mm.
JP
Good news is, the difference is only 8mm
If manual focus isn't the issue, what is? Size? Minimum focusing distance? Aside from those things, it's hard to fault the Zeiss!
I primarily use the 77 ltd for portraits, and candids where I personally don't have the time or skill to focus manually. On the K7, the focus is very fast. I enjoy the lens a lot more on the K7 than I did on the K20.
The Zeiss 85 is hard to beat in IQ and bokeh, but the 77 has a different look to it (different colour and rendering), so I wouldn't worry about overlap. I say if you can find one at a good price, or even a bad one, get it!
