07-13-2007, 01:00 AM   #1
LeGoGubbe's Avatar
fake macro with 50-200
i've seen that you can take macro shots with the kitzoom, but i can't find what is needed think it was an adaptor of some kind.
if any could give some tips that not involve buying a real macro ( ) it would be really great.
thx !
07-13-2007, 01:33 AM   #2
Branimir's Avatar
You have to use closeup lens.
For example this
07-13-2007, 01:36 AM   #3
LeGoGubbe's Avatar
aaahh ! i'll take a look. does the image quality degrades a lot with these ? any other tips ? thx barnimir !
07-13-2007, 03:56 AM   #4
raider's Avatar
I think you can also use an extension tube which does not degrade the quality of the picture.
07-13-2007, 08:36 AM   #5
LeGoGubbe's Avatar
extension tube that sounds interesting, any idea of which "model" to use ? and is it better with the 18-55 or 50-200 ?
thx
07-13-2007, 02:28 PM   #6
Longer lenses result in longer working distances, which often makes life easier.
Also many extension tubes state that they should be used with lenses with a 50mm or longer FL.
Closeup lenses:
Pros - You maintain AF, and are guaranteed to retain automatic aperture. In short, maximum compatibility and ease of use.
Cons - Very few closeup lenses are achromatic doublets. Those that are will be quite expensive. Non-achromat closeup lenses will add chromatic aberration. I've gotten decent results with my +1 and +2 Tiffens, I haven't tried the +4 diopter lens on its own, but the results with all three stacked were abysmal - severe CA and general blurriness. The set was $50.
Extension tubes:
Pros - No degradation of image quality
Cons - With a few very rare exceptions, you will lose AF. Although in the extreme macro range, unless you have a lens with internal focusing (neither the 18-55 nor the 50-200 do) AF will not work as the focusing mechanism will change the working distance. You'll need to move the camera closer/farther away from the subject to focus. (this is why people sell focusing rails, but if you have a short tripod with an extendable center column this will work OK for straight-down macro shots.)
Also, cheap extension tubes will remove auto aperture functionality, which will stop any P-TTL flashes from functioning and make exposure a general pain. More expensive ones will preserve auto aperture.
In short, the extension tubes will be more difficult to use but will provide better results.
07-13-2007, 03:59 PM   #7
roy
roy's Avatar
QuoteOriginally posted by Entropy Quote
Extension tubes:
to use ETS with the kit lens you will have to have a set of at least A electrical contacts. otherwise you will not only loose AF but also the ability to set the aperture as the kitlens does not have an aperture ring.
07-13-2007, 04:37 PM   #8
FotoPete's Avatar
The Kit gives the impression of 'macro' because of its rather close focusing distance. You can set the zoom to 55mm for an even higher magnification.
07-13-2007, 05:30 PM   #9
QuoteOriginally posted by roy Quote
True, I should have pointed out that with the kit lens and the DA 50-200, auto aperture functionality is essentially required as those lenses do not support manual aperture functionality.
Note: There are a number of eBay vendors that are currently selling extension tube sets that are "full manual" but show a DA-series lens mounted. Beware! Don't be fooled by the photo, they are showing a fundamentally incompatible lens/extension tube combo! That's the reason I haven't bought extension tubes yet - Extension tubes that support autoaperture on eBay are rare, and new ET sets are $150ish.
07-13-2007, 08:50 PM   #10
check raynox dcr-250 out.
here's a sample of what it can do when coupled with the DA50-200.
07-14-2007, 05:26 AM   #11
raider's Avatar
How much did u get for this raynox dcr-250?
07-14-2007, 07:12 AM   #12
LeGoGubbe's Avatar
omg raynox got me
07-14-2007, 08:53 PM   #13
i got it for $40 online. it performs well as an alternative to a macro lens. i'm sure you won't be disappointed with it. for 40 bucks, give it a try.
07-14-2007, 09:09 PM   #14
raider's Avatar
For the bug picture, how far are u standing away when u are using the DA50-200 with the raynox?
07-15-2007, 04:21 PM   #15
i was pretty close to the wasp... i'd say about a few inches from him.
k-mount, macro, pentax lens, slr lens
People Fake blood! wshi Post Your Photos! 3 10-11-2010 07:28 PM
Is wrestling Fake? joodiespost General Talk 21 10-08-2010 09:01 PM
Leica S2 - fake or supermachine? ogl General Talk 38 09-23-2008 05:49 AM
Fake Pentax A 85mm Eastern Shore Charlie Post Your Photos! 4 08-31-2008 08:25 AM
K20D pic or fake? ;) bravobrown Pentax News and Rumors 17 12-07-2007 04:08 PM
All times are GMT -7. The time now is 11:20 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
