Sinan on dpr asked for this and it would have helped me decide to get a different CP filter and Cokin filter holder (I'd get either a configurable Lee or cheaper single slot Cokin P and get the slim Hoya Pro1 CP instead), so I'm putting this up to help others avoid the mistakes I made
Test setup:
K10D w/ Sigma 17-70 pointed at beige wall set to f/11, 17mm and manually focused at 7' because AF didn't work. An SB-28 flash in 18mm auto mode set to f/11 and ISO100 to match the camera was also used and pointed downwards -7 degrees with a stofen diffuser on it. Camera was put on bogen tripod and leveled.
72mm B&W UV filter only (just the Sigma 17mm vignetting shows up):
77 B&W Kaeseman (non-slim) CP on 72-77mm stepup over the above B&W UV filter:
77 B&W Kaeseman CP on 72-77 stepup directly on lens:
Cokin 3 slot P filter holder on 72-77 stepup over B&W UV filter:
Cokin 3 slot P filter holder over stepup over B&W UV filter but zoomed to 19mm with filter holder slighly non-level:
Cokin 3 slot P filter holder w/ 72-77 stepup directly on lens:
