Originally posted by JeffJS You should probably note which TC it is. There are many available for the K mount (used of course). The TC is the Vivitar 2x Macro focusing, PK/A. No, this TC will not autofocus so if your desire in buying an FA lens to use with it, it will be like spinning tires on a grease slick. The TC will allow you to do auto everything else though so you can use Aperture priority (with an A or later lens). That isn't to say that an FA50 wouldn't be a good lens to have but for a TC, the autofocus is a waste of money. It was my experience that the best performers on this particular type of TC was the A50 f1.4 though the 1.7 is no slouch.
Yeah I was thinking of an A50 F1.4 or 1.7. FA 50 would still work though right? (dumb question... but can you manual focus a FA 50? I was considering the M line as well. Yeah I'm just basically looking for some okay fast 50mm okay bokeh lens. Where the doubled function would be being able to be used as a macro on the Vivitar 2x Macro TC PK/A. Everyone needs a good 50mm ;D!
Originally posted by RioRico You may find that AF is wasted in macro work. Since you say you want a 50mm prime, I assume you'll be shooting in a studio, where hopefully your eensy weensy subjects won't run off. (50mm is a bit short for most field work.) Macro shots have razor-thin DOF anyway, and you'll want to focus carefully, manually. Using a non-AF TC will disable matrix focusing and focal point selection, so focus confirmation only works at the center point. Bother. I think you'll find that many folks doing 50mm macro work use the cheap, brilliant Industar-50 f/3.5 on M42 tubes, and spend a lot less than your budget. Like, the high end on lens plus tubes is maybe US$50. Have fun.
Hmm... with the Vivitar 2x Macro TC PK/A wouldn't it turn a 50mm lens into a 100mm macro? (sorry I didn't specify). I wouldn't use AF much in macro anyways, I don't need it, but it would be fun to have. As a normal 50mm lens though, it wouldn't help to have one. Eh, ;( I already bought the TC... so I don't think I will be switching to tubes anytime soon. Yeah I would save my money. I am looking for a fast 50mm lens while I'm at it though so I'm going to spend a bit.
Thanks for the info though, maybe I'll consider this in the future
Yeah, I never knew that a 50mm macro would most likely be used in a studio. Bugs are afraid of me ;(.
