03-31-2010, 11:58 AM   #1
FD to K
I did a search and did find a few post on this but they where old and just wondered if anything new has arouse from this. i have several FD lenses at home along with FD bodies. now i got my new K-x and i really don't want to start dumping a lot of money in lenses again. (going to get the da 55-300) has anyone got any new info for mounting these or is it never going to happen.
03-31-2010, 12:36 PM   #2
boriscleto's Avatar
Not going to happen because of the registration distance. Not much of a market for FD lenses either. They do make a FD adapter for M4/3 so maybe the market will pick up.
03-31-2010, 12:44 PM   #3
emr
Guest
How about just getting a m4/3 camera with the adapter as a secondary
setup for yourself?
03-31-2010, 12:56 PM   #4
emr
Guest
Another option is the new Samsung NX10 w/ adapter.
03-31-2010, 01:04 PM   #5
RioRico's Avatar
QuoteOriginally posted by Oddity96 Quote
There are several ways to use a FD lens with a Pentax dSLR.
1) Get PK lens reversal adapters to fit the front threads of your lenses. They're cheap. Mount a lens on the camera, reversed. Shoot macros. Use good lighting.
2) Find a FD-M42 adapter, a M42-PK adapter, and a M42 bellows. Mount lens on bellows via adapter #1. Mount bellows on camera with adapter #2. Shoot macros.
2a) If you can't find a FD-M42 adapter, disassemble the FD lens and mount any of the lens elements on the M42 bellows with gaffer's tape. Enjoy the fine optics.
3) Perform surgery on your FD lenses. I've seen web pages detailing just how much machining is necessary. Then add PK mounts. Be sure to use good solder.
4) FD lenses make excellent paperweights to hold down your Pentax booklets, printouts of lens price lists, Adorama receipts, credit card statements, maps, etc.
5) Throw FD lens high in the air and use Pentax camera and lens to photograph it as an Alien Entity or giant roc seizes it and carries it away to the end of forever.
Also: Pioneering prospectors sometimes built "bottle houses" of discarded beer etc bottles cemented together. Collect FD lenses, build a "Canon Lens House". They're also useful as Xmas tree ornaments, fishing sinkers, ant and caterpillar burners, weights for bolos, firearm target practice, etc. You can never run out of things to do with or to them. Have fun.
03-31-2010, 02:25 PM   #6
https://www.pentaxforums.com/forums/pentax-slr-lens-discussion/95710-new-pentax-85mm-1-2-a.html
03-31-2010, 02:44 PM   #7
only one problem i don't read Russian
Переделка объектива Canon FDn на Pentax - Форумы Пента-клуба
03-31-2010, 02:47 PM   #8
hahaha you a funny guy
like i said i have three bodies at home these fit so the do get use.
03-31-2010, 02:52 PM   #9
QuoteOriginally posted by emr Quote
this is a idea
03-31-2010, 02:53 PM   #10
QuoteOriginally posted by boriscleto Quote
setup for yourself?
not to fond of a small body with a big lens on it. for some reason it just don't seem right
03-31-2010, 04:59 PM   #11
Google up Translate this page, and you should be set.
Since you really don't want to modify your lenses, if you still want to shoot your old Canon's I suggest that you modify a teleconverter. Sure you'll extend the lenses, however they'll still be useful with both systems.
03-31-2010, 05:31 PM   #12
Pentaxor's Avatar
once you tried some of the Pentax glasses on, you would no longer consider putting your FD glasses on. there are a lot of great MF Pentax and 3rd party glasses on K-mount that are available and a lot of M42 lenses that you will only need a PK-adapter that you can find cheap.
the 16-45 and 55-300 are enough to answer your AF zoom range needs. this would cost you about $350 only. and the specialty manual focus lenses such as 28/2.8, 50/1.4, 85/2, 100/2.8 or f4 macro, 135/3.5, 200/4 would cost you around a total of $500. without the 200/4, that's only around $400.
03-31-2010, 06:31 PM - 1 Like   #13
Douglas_of_Sweden's Avatar
6) Buy an FD to K adapter canon FD adapter to Pentax K200D K110D K7 Kx Km K2000 - eBay (item 200453836000 end time Apr-22-10 22:21:11 PDT)
Sure it has some optical lens element so you will get some degradation of optical quality, but it doesn't cost more than that it is worth testing.
03-31-2010, 06:48 PM   #14
boriscleto's Avatar
QuoteOriginally posted by Douglas_of_Sweden Quote
I didn't know they made an FD to K adapter. I knew about the Nikon F/AI to K adapter.
This one's even cheaper
http://cgi.ebay.com/Optics-glass-Canon-FD-lens-mount-To-Pentax-PK-Adapter_W0...5#ht_835wt_941
03-31-2010, 09:57 PM   #15
QuoteOriginally posted by Pentaxor Quote
I'm not putting down Pentax here, however I've been told by several people that some of those Canon FD mount lenses rival, and even beat their Zeiss equivalents.
fd, k-mount, lenses, pentax lens, slr lens
All times are GMT -7. The time now is 11:20 AM. | See also: NikonForums.com, part of our network of photo forums!
