04-01-2010, 02:48 PM   #16
Blue's Avatar
This young lady makes the M 85mm and photographer look very good!
QuoteOriginally posted by yeatzee Quote
I'll give a couple quick test examples from each of my M lenses:
M 85mm -
wideopen -
F/2.8 -
wideopen -
M 50mm -
F/2 -
M 200mm (only shot I have online) -
wideopen -
Note: These are all on the spot shots where I did not properly set up or anything. For example the M 50mm F/2 shot is inside a restaurant for my sisters birthday. The first M 85mm shot is a quick snapshot while on a walk.... etc. etc.
04-01-2010, 02:51 PM   #17
QuoteOriginally posted by Recercare Quote
*Today I have been shooting with my new K 35mm F3.5. It is an amazing lens, sharper than my DA 40mm F2.8 Ltd and there's no equivalent in the M-series.
There is the M 2.8/35mm. It seems to be valued less though. There also is a 2.0/35 version, however, in the K, M and A-series.
*I have tested the K 200mm F2.5 (but only for a short time) and compared it to my M 200mm F4 (which is now sold). Well, the K is a lot better, and then I mean A LOT better.
Thanks for your impressions! Very useful.
04-01-2010, 02:52 PM   #18
BTW, something I just noticed looking at Yoshihiko's site:
http://www.takinami.com/yoshihiko/photo/lens_test/pentax_tele.html
Check out the M85/2 results. I had always noticed that they look terrible compared to most others lenses in that range, and most at odds with what others report on DSLR's. But something I had never noticed before - his results (from film) show the lens being *better* in the corners than the center at larger apertures. That's unheard of. Makes me think something went drastically wrong with his test, or with his copy of the lens itself.
Yes, something is wrong. Maybe he tested a bad copy. I have this lens and it's very sharp.
Resolution is not everything anyway. I tried the M 28mm F2 today, which according to the test should have higher resolution than the K 28mm F3.5.....but my K 28mm F3.5 was indeed sharper.
Kind regards
.lars
04-01-2010, 03:15 PM   #19
Just1MoreDave's Avatar
QuoteOriginally posted by Smolk Quote
I like the M version a lot better because the K is 50% bigger and heavier. For a slow lens, I can't see carrying the K for a small IQ gain. If you believe one test, the K is 4% sharper in the center. Not enough for me.
04-01-2010, 04:21 PM   #20
8540tomg's Avatar
I’m not sure I have much to offer to the K vs. M debate here beyond opinion but here goes. As you can see from my signature I have a number of M and K series lenses. I like them all and they are all fine lenses. I do prefer what I consider to be the more robust construction and heft of the K series. I also prefer the colour palette of the Ks I own as they seem to produce more pleasing images at least to my eye. This is all very subjective stuff of course and you can take it for what’s its worth.
I can’t speak with authority on any other lenses but I do own both the K 200/2.5 and the M 200/4. I have used both extensively. While the M is a nice lens I can state categorically that the K 200/2.5 is superior in every conceivable way. It should be, as you will probably have to pay 3 or 4 times as much to get one if you can find it. It is sharper, heavier, better built and remains the fastest 200 Pentax ever built. A big bonus is the extra brightness you get with the 2.5 every time you look through the viewfinder. It is a lot easier to focus as a result in low light situations. Whether you use the extra speed or not that brightness is always there. You do get what you pay for with this lens and if you have the need for a fast manual 200mm the K 200/2.5 is a good choice.
Jsherman999 once said this lens has “sharptitude.” I think he is right.
This shot was taken hand held last summer.
yeatzee wrote
"I've been spying the K club but to be honest I've yet to see half the quality of shots posted in the M club. In fact Im having trouble finding just one picture that really makes me want to buy a certain K lens or replace one of my M lenses.
Soooo.... why K? "
Perhaps this might convince you?
Tom G
04-01-2010, 04:35 PM   #21
QuoteOriginally posted by Just1MoreDave Quote
I don't measure in % when doing real life comparisons
I don't quite understand your point about size, but I guess it's a matter of taste. Both 28mm F3.5 lenses are small enough to be used hand-held without any problems. They fit easily in a small camera bag and they're not obtrusive when mounted on the camera. To me it does not matter whether a lens weighs 100g or 250g as any lens lighter than 300g will be comfortable to use unless it's too long. The same goes for length: Whether a lens is 1cm or 3cm long is not important as any lens shorter than 5cm is within my comfort zone.
However, I do understand that people prefer the M 28mm F2 over the K 28mm F2 as the latter mentioned is 7cm long. The same goes for M 135mm F3.5 vs K 135mm F2.5 where the latter mentioned is so heavy and long that some people can find it uncomfortable to hand-hold.
Kind regards
.lars
04-01-2010, 05:13 PM   #22
jsherman999's Avatar
QuoteOriginally posted by 8540tomg Quote
Tom G
This shot just kills me every time I see it. Look at the detail and tonal range in the feathers on the back, and of course the sharpness...
04-01-2010, 05:49 PM   #23
gofour3's Avatar
Soooo.... why K? "
Tom G
Yes a great shot Tom, the “Jedi Master” of the K200/2.5!!
Phil.
04-01-2010, 05:58 PM   #24
8540tomg's Avatar
Thanks Jay.
I always appreciate your comments and opinions.
Thanks Phil - my young padawan. May the K force be with you. Always.
Tom G
04-01-2010, 06:31 PM   #25
Pentaxor's Avatar
why K? because the lenses are based from the SMC Taks which are great lenses optically and that some K lenses are part Carl Zeiss design which makes those lenses a bit more sought after. there are possible compromises to IQ on both sides. some have improvements while some got worse. it's a matter of telling which lenses are those. but for my part, I love the resolution, color and soft bokeh rendering of the K55 as opposed to the M50f1.4, M50f1.7 and M50f2. it would help if you are able to try it and what makes it tick for some owners. it's either you will find the images interesting or not.
unprocessed in-camera jpeg image taken with the K55. I love the bokeh of this lens.
04-01-2010, 08:17 PM   #26
8540tomg's Avatar
I said above I prefer the "look" of the K series lenses to the M series. As a rule this is usually the case. I've got to admit the Ms do have their moments though. The M 400/5.6 really nailed the colours and hues of this Chickadee.
This old lens has a bit of "sharpitude" as well. I'd say it also has the "M" look to it.
Tom G
04-01-2010, 08:56 PM - 1 Like   #27
monochrome's Avatar
I started a response today then got interrupted.
I think there is a matter of taste - the M optical designs and coatings are different from the K - not necessarily conditional, just different.
Some K lenses are clearly the best at their FL Pentax ever made, at least in MF.
Same could be said for some M lenses and A lenses.
There is the subjective. Some people favor bokeh, some sharpness - that leads to different opinions.
There is the tactile pleasure of using a lens. Some people care about that, some don't. Generally, tactile people order the lens lines Takumars best, K next, M next, A can be great or not, F/FA generally pretty unpleasant in manual shooting.
A Canadian named J. Colwell consolidated the opinion first posted on the internet in the late 90's through 2005 and ranked (SPLOSdb.pdf) the Pentax lenses from Tak through the FA's then available. His consolidation of then-current opinion of the outstanding (!) non-* MF lenses was:
K18/3.5
M28/2
K28/3.5
K28/3.5 Shift
K35/3.5
A50/1.4
A50/1.7
K85/1.8
K135/2.5
K200/2.5
The next level (merely Excellent) contains virtually every other lens discussed in this thread. None of this is to say K is better than M generally, but that the best MF lens for a given FL is often the K series. In my limited experience the difference is often (but not always) de minimus.
This ranking purported to consolidate opinion from a number of sources and was specifically NOT driven by his own opinion. Take all of this with some salt - the FA77 Ltd was not ranked Outstanding (!) - merely Excellent ** - and shoot what you like the best!!
04-01-2010, 11:58 PM   #28
yeatzee's Avatar
Wow guys! Great responses so far! Keep them coming.
This is part of the reason right here - the K's focus action feels like a Takumar - longer throw, maybe just a tad more dampened and 'smooth'.
Optically, at the lineup level - the K line vs. the M line - no real advantage.
I've been saying that for a couple years now about Yoshihiko's M 85 test. He either had a bad copy, or his test was basically hurried, or compromised in some other way.
My M 85 f/2 is better than my Nikon 85 1.8 and just about as good (if not as good) as my 77ltd.
Being as I've never used a Takumar im not quite sure what you mean about the above I do agree about that fluked test.... the M 85mm pictures speak for themselves.
QuoteOriginally posted by gofour3 Quote
My suggestion is for you to get one of the cheaper K series lenses, like the K28/3.5, K35/3.5 or the K55/1.8 and try it out. You won’t find three better lenses for the money and you’ll soon be converted to the “K” club.
Phil.
I'll have to look for them... though AFAIK they go for a fair amount more than their M counterparts and I am supposed to be saving for the K-7 My lens lineup has nothing wider than 50mm other than the Kit lens so I've been looking into a 20mm+ lens. Maybe I'll sell the M 200mm to dent the purchase
Ha that she does
http://farm3.static.flickr.com/2636/3845144025_f7cf9f7668_o.jpg
Soooo.... why K? "
Tom G
Nice sharp all around shot Tom... what aperture? No surprise its better than the M 200mm... I personally am not willing to pay that much for a manual 200mm lens sadly, unless it was a macro . Now why don't i see any decent shots from any other K lens?
QuoteOriginally posted by Pentaxor Quote
http://i290.photobucket.com/albums/ll271/angkokok/dakota.jpg
Thats the key.....
And personally I think the M 50mm F/1.7 has fantastic bokeh. Look at the example I posted... if you look past the highlight bokeh its quite good IMO.
04-02-2010, 07:16 AM   #29
GeneV's Avatar
Kind regards
.lars
Size and weight do matter to a lot of us. The sharpest, most beautiful lens in the world does you no good if you leave it at home. My size/weight splurge is the SMC k135/2.5. I appreciate its magic, but I don't think I would haul a whole bag full of lenses of that kind of size and weight very often on a long hike or a travel excursion in a bus.
04-02-2010, 08:09 AM   #30
SteveM's Avatar
I am one of the posters in the K club so I might be the guilty party as far as the quality of the pictures go.
I have had many M and K lenses but standardized on the Ks mainly as I had a few that I really liked as compared to the Ms I owned at the time. I still love the K85/1.8 and feel it is my favorite lens. I've never handled the M85/2 so I can't compare that one but here is a link hwere you can...
The Great Pentax 85mm Lens Shoot-Out
I don't think you can go wrong with a K or a M..
28mm, 50mm, f/2, im, k-mount, lens, lenses, pentax lens, people, slr lens
People Which of the 3 would you prefer, if any? m8o Photo Critique 20 10-13-2010 07:51 PM
People Which One Do You Prefer? jaieger Post Your Photos! 7 09-16-2010 07:02 PM
Which one you would prefer, K-7 or K-x ? cbaytan Pentax DSLR Discussion 37 02-08-2010 04:02 PM
Misc Which one do you prefer? YJD Post Your Photos! 14 10-21-2009 05:51 PM
Which of the two do you prefer most and why? LeDave Photo Critique 10 07-24-2009 02:25 PM
All times are GMT -7. The time now is 04:24 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
