04-03-2010, 02:53 AM   #1
stillshunter's Avatar
Over-exposure with TC
Just wondering if anyone had similar experience, and advice, on exposure with a teleconverter?
The Sigma 100-300/4 is a nice marriage on the K20. Just for a little more reach I recently added a Sigma APO 1.4x TC. Although it is pretty useless with most my other lenses I thought it was the best fit for the 100-300/4. Well had my first test today and it seems the rig with TC is now over-exposing by two stops. Is this normal? I tried spot, centre-weighted and matrix metering and each seems to over-expose....though spot a little less.
I fear light leaks but a web-search says that a teleconverter can require a little adjustment...but two whole stops
I'm used to winding the EV up or down for my older glass (K or M) but not with the newer AF offerings.
Looking forward to others experience as the longer reach is good but not at the expense of blowing highlights....
04-03-2010, 04:55 AM   #2
Lowell Goudge's Avatar
Its ddue to the focusing screen, which has a funny characteristic which impacts the metering , combined with the fact thY the sigma TC does not correct the lens aperture but feeds the lens data right through
the K10D is the same
search for posts on metering with manual lenses for mor details
04-03-2010, 11:40 AM   #3
I've noticed strange readings with TC's. If you have PhotoMe you can read off the meter readings with and without the TC to get the exact difference. Just type LV in the search box. I use the value for Segment 1.
It might have something to do with the values of TC's being just nominal one's i.e. a 2x could be 3x on certain lenses.
I just use trial and error to find the correct exposure when using a TC.
shim
experience, k-mount, pentax lens, sigma, slr lens, spot, tc, teleconverter
K7 Exposure... spartan Pentax DSLR Discussion 9 12-02-2009 07:53 PM
Exposure. sebberry Troubleshooting and Beginner Help 5 11-20-2009 08:09 AM
what don't I get about exposure? FHPhotographer Pentax DSLR Discussion 34 09-11-2008 07:12 AM
Night photography with K10D - High ISO short exposure VS Low ISO long exposure pw-pix Pentax DSLR Discussion 10 02-03-2008 01:37 AM
I need some help, WB/Exposure? Drinksmixer Pentax DSLR Discussion 2 07-13-2007 10:15 AM
All times are GMT -7. The time now is 03:45 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
