01-04-2011, 11:38 AM   #16
Ira
Ira
can you photograph the broken tripod mount
depending on where the break is, I might have some ideas.
Thanks, but I've since fixed it with epoxy. Basically, the tripod socket (the little piece) just broke off from the collar. There are no screws or anything holding it on, so one has to assume it's actually part of the collar, and just bad metal strength there.
I'll have no problem sticking this on a tripod now, but I would want to run a ittle safety wire/cable around the lens and attached to the tripod. In case the thing takes a crap again, the stuff won't fall to the ground but just swing a little and bang into the tripod.
Again, I can't imagine when I'm going to ever use it, but the value isn't worth selling. Maybe one day I'll get motivated and come up with a reason.
01-04-2011, 11:53 AM   #17
Lowell Goudge's Avatar
What it sounds like, and I believe there is a way to strengthen it, is to drill and either screw or rivit the foot to the collar, using a countersink so that surfaces remain flush. While the glue will take the majority of the load, a screw will help in the "Peel" mode where adhesives are worst from a point of view of strength.
01-04-2011, 02:35 PM   #18
Ira
Ira
I'll give it a shot later tonight, but where the piece broke, there's not much material to drill into.
I could literally just use strapping tape to make sure the thing doesn't go anywhere...pop a hole in the tape to take the tripod screw...and I'm safe.
Not pretty, but it will work from a safety standpoint.
And I'm kind of feeling that everyone should have at least one really ugly and stupid lens in their bag, as long as it does the job.
day, k-mount, pentax lens, slr lens, vivitar, vivitar 400mm
For Sale - Sold: Vivitar AF 100-400mm f/4.5-6.7 LMagee Sold Items 4 09-12-2009 01:38 PM
Vivitar 400mm moon shot Igilligan Post Your Photos! 8 12-20-2007 02:39 PM
Vivitar 400mm F5.6 NaClH2O Pentax SLR Lens Discussion 12 11-16-2007 06:28 PM
New Vivitar 400mm test shots Stratman Post Your Photos! 8 09-18-2007 07:43 PM
For Sale - Sold: FS: Vivitar 400mm f/5.6 igowerf Sold Items 6 09-06-2007 07:34 PM
All times are GMT -7. The time now is 08:37 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
