what lenses do you have.
Note that while sigma makes some very good TCs they only work with a select few sigma and pentax lenses because the front element of the TC projects 10-12 mm into the rear of the lens.
the two shots below were taken using a sigma APO 70-200F2.8 EX and sigma 2x TC
the first is a K10D at ISO 1600 and is cropped to about 10% of the frame
the next is a full frame right out of the camera
the next 2 are using an SMC 300 F4 and pentax SMC-F 1.7x AF TC
first with *istD and flash. The shot is only cropped about 10%
second hand held with K7 at 1/40th This cropped and displayed at 100% resolution
Both TCs are very good when mated to a good lens. The pentax TC is a little more versitile since it can be used with almost any lens, but on an AF lens, the lens focusing is disabled, you need to manually focus close then the AF element in the TC does the rest.
