04-05-2010, 08:38 PM   #1
KxBlaze's Avatar
Different mounts on a Kx
I am a newbie so this is probably a novice question but I searched for this type of question but could not find anything.
Will a 645, a 67 and a M42 screwmount fit on my Kx?
Will any of them need adapters?
If any of them fit, what will they lose? AF, etc...?
04-05-2010, 08:47 PM   #2
645 and 67 will fit on the Kx with an additional adapter that costs quite a bit, $200 last time I checked on Ebay.
M42 will fit on the Kx with a $10 adapter ($30 if you want the Pentax version), I recommend ponying up the money for the Pentax brand as it has a tool-less release. Beware of Pentax lookalike, just because it says Pentax on it doesn't mean it's made by Pentax.
I'm not aware of any adapter that retains the use of AF. You will typically need to use stop down metering and aperture ring. It will be 100% manual.
Pretty sure there are stickies devoted to this as well as the search forum function. But alas, I feel like spoiling you tonight.
04-05-2010, 09:01 PM   #3
KxBlaze's Avatar
QuoteOriginally posted by hangu Quote
Thanks. I did the search function, typed in "different mounts", "M42", "645", and "67". None of them showed any thread that flat out stated whether or not those would fit on a Kx.
Another question, an M lens will fit without an adapter right? I know it's a manual (no AF).
04-05-2010, 09:05 PM   #4
QuoteOriginally posted by KxBlaze Quote
All K mount lenses will fit without an adapter.
04-05-2010, 10:02 PM   #5
Yes, M mount lenses will fit on the Kx.
Actually, any lenses in this list of K-mount lenses will fit:
Pentax Lens Review and Specification Database - Pentax K-Mount Bayonet Lenses
k-mount, kx, pentax lens, question, slr lens
flash mounts Falld5 Flashes, Lighting, and Studio 5 01-03-2010 05:10 PM
need help are all k mounts compatible autosri Troubleshooting and Beginner Help 7 11-15-2009 11:04 AM
A mounts on k20d iasonis Troubleshooting and Beginner Help 2 06-23-2009 06:58 AM
Older K and M mounts ghost Pentax SLR Lens Discussion 8 03-23-2008 09:13 PM
Old screw mounts. magnum1 Pentax SLR Lens Discussion 12 11-15-2007 09:27 AM
All times are GMT -7. The time now is 06:27 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
