04-08-2010, 08:27 AM   #16
QuoteOriginally posted by Canada_Rockies Quote
The Nikon solution is to automatically crop when the APS-C lens is attached to the body. The camera body "discards" the coverage outside the APS-C image size. I'm not sure whether this is an advantage or not.
I am sure that some Nikkor lenses, as do Pentax lenses, cover the APS-H frame size at some focal lengths, and some even 24x36 mm frame at certain focal length settings. With the Nikon system, even if your lens covers the full frame at the longest focal length, you will only get the cropped version.
You can turn this automatic function off, Albert. That way you can choose yourself which format is to be used: FF of APS-C.
04-08-2010, 07:47 PM   #17
Marc Sabatella's Avatar
QuoteOriginally posted by jct us101 Quote
That's funny, because of the vignetting is pretty bad on crop cameras with the first version of it! I assume you tried it with the Mark II that doesn't have a problem with vignetting?
There's vignetting in the sense of slight darkening of the corners, and vignetting in the sense of completely black corners. When someone talks about a DA lens vignetting or not on film, it's the latter they are talking about - not whether or not there is slight darkening.
04-09-2010, 05:28 AM   #18
Lowell Goudge's Avatar
QuoteOriginally posted by systemA Quote
I also use the Sigma 10-20mm/4-5.6 on a full frame Pentax LX. Workable focal range is 12-20mm without noticeable vignetting, but with no auto-aperture ring setting, I'm stuck shooting wide open.
that's why I suggested a PZ-1 to the OP.
it can work with every lense ecept HSM
04-09-2010, 06:33 AM   #19
Senior Moderator
Parallax's Avatar
I see that as an advantage since it is a user selectable option.
da lenses, dslr, ff, k-mount, lenses, lenses with pentax, pentax, pentax ff, pentax lens, slr lens
Pentax DSLR with analogue Lenses: A question! rieby Pentax DSLR Discussion 5 11-23-2009 12:56 PM
Minolta AF lenses on Pentax DSLR shittii Pentax SLR Lens Discussion 1 11-04-2009 05:25 AM
Old Pentax Lenses + New DSLR Bubbabob Photographic Technique 28 06-25-2008 01:25 PM
Compitability of Pentax P30 SMC-A mount lenses on Pentax DSLR vinpura Pentax DSLR Discussion 2 02-04-2008 08:25 AM
Pentax medium format lenses on a DSLR? Rorschach Pentax SLR Lens Discussion 9 12-18-2007 06:30 PM
All times are GMT -7. The time now is 10:07 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
