Originally posted by RioRico I'm sorry, but stuff DOES happen outside those ranges. Very interesting stuff. Stuff happens in the distance; or details are just beyond our reach.
True, but in my experience, the stuff that happens in the distance while traveling isn't usually any more interesting than the stuff that happens in the distance at home, and is far less interesting than the stuff that happens right around you while traveling. Looking at my own usage of my lenses while traveling, I use pretty much the whole range up to around 70mm and then it starts dropping rapidly. So having 50mm for my max wouldn't bother me as much as I might have thought a few years ago.
But I'd be lost without the 24-50 range, as I do the majority of my shooting there.
My simple travel kit would be either my DA15, M28/2.8, and DA40, or 18-55 plus the 40. But really, I have no problem also carrying my DA70 and/or M135/3.5 with me. Total weight of all these lenses is no more than that of a couple of zooms other might suggest. The way I shoot, I don't actually change lenses all that often, either, plus I'm good about changing while walking, so it doesn't particularly slow me down either. YMMV.
EDIT: a quick tally suggests the total weight of my 15, 28, 40, 70, and 135 is about 850g. Leaving the 135 at home would cut that to under 600g - less than that of the 16-50 alone. A 28-75 plus 10-20, 10-24, or 12-24 weighs over 900g. 18-55 plus 40 comes to barely over 300g.
