Originally posted by and Deffinetley not a 2x of any kind, you loose 2 stops and get a bit degraded image quality.
You want to get over 300mm? crop your 250mm....
If you should decide to get a tc then I belive the tamron 1.4x should be your best bet.
Originally posted by SupremeMoFo A 2x teleconverter will give you a 36-500mm f7-12.6 lens, which is a shocking aperture range to be working with at the long end especially. I'd leave it at a 1.4x.
I'd agree with both. Get the 1.4x You don't loose too much speed (about one stop) which can be compensated with a boost in ISO and that will give you about 350mm at the long end. The other option is to take the shots as sharp and steady as possible with the thought of cropping the picture later to magnify to your desired result. The combination of lenses you suggest is great for almost any situation.
If I may suggest (and you may have already considered this), you should take as many good SD cards or a memory storage device so you can shoot as much as possible in RAW (PEF to get the most out of the cards). It will give you more to work with when you are cropping and PP'ing a shot. Maybe a card reader would be a good idea since you could email yourself from an internet cafe, the files to a Gmail account which has almost unlimited storage. Also consider a decent, lightweight monopod and/or one of those small fold up mini tripods. The Mini tripod will allow you to set the camera up on any surface, a rock, table, fence post etc. and could make a huge difference in a good shot or a great shot. It could really help with those longer shots.
Sounds like a fantastic trip and we'll all be waiting to see the results.
EDIT: As RussellW says below the Sigma 50-500 f4-6.3 EX is a great lens. I also have one and it will fit in my backpack bag without issue. It is 1.8Kg x 95mm Dia x 218mm L so not too big for a decent bag. Long and sharp and easy enough to hand hold. If you can find one before your trip it would be the best solution. Only issue is they run around $1000 USD used and about $12-1400 new.
