Originally posted by solar1 ----- Not everything that counts can be counted - Albert Einstein
------ Interesting Tidbits Department of Tidbits
"Q: Klaus, why do you consider the K-5 to be superior to the D7000? Other than a couple of extra fps and the in-body IS, it seems to be on-par with the Nikon or even trailing (AF points, metering), while costing $400 more.
A: It's smaller & more rugged. Body-side IS as you mentioned. And more important than anything else - Pentax has a complete dedicated APS-C lens lineup. Nikon has merely isolated solutions here specifically regarding primes."
"I think there's absolutely no doubt that Pentax has, by far, the best APS-C lineup out there. It's not even a close call. Full format lenses on APS-C DSLRs are always a compromise - at least in terms of size/weight."
"Well, I think this one is fairly obvious. Pentax is basically the only manufacturer offering APS-C pancakes. If you want to stay small with primes there's no way around Pentax. The Pentax 60-250 is also unique. There're more. This is basically the advantage of a dedicated APS-C lineup and not some sort of mix."
"The D7000 has "magnesium-alloy top and rear cover". The K-5/7 has also front and bottom plates made of metal. It is also likely that it has more seals.
The K-5/7 is a D300 class body, the D7000 is an upgraded D90 or downgraded D300, whatever you wish."
"Anyway, technically the K-5 seems to be the best new APS-C DSLR of the season. It seems superior to the 60D/D7000/A55/E5 to me at least."
Chief Editor
photozone.de
______________________________
I must be doing something wrong.
When ever I attempt a search on key words, key terms, direct quotes, etc. I turn up nothing.
Can anyone help me identify the original source for this exchange and provide a link?
Cheers...
