Originally posted by Eagle_Friends Hey everyone, I'm stuck deciding which prime to go with. The price of the 35mm is cheaper, and the make more sense as a walk-around lens, also the macro feature will come in handy during certain situations. But I already have several prime lens in the 28-50mm range, just ones not as good. I do not have a wider prime and was wondering what you guys here think would be a better lens.
Thanks
Go with the 35 mm. It is a wonderful lens. No disrespect to the 15 mm. Members like Jay here make it look great (much to the rest of our demise
). Really, though, you have to know how to use it and compose properly. There is a reason that you have 'several prime lens in the 28-50 range...' That is where you like to shoot. The highlighted portion of your post says it all. If you have a kit lens that goes down to 18mm, do you wish to go wider for your shots? Fill your needs now. That is not to say that in the future you won't want/need a WA. But, if you want to start to build a collection of great lenses that cover the types of photography you shoot, go with the obvious one you will definitely use the most-the DA 35 mm Limited. I rest my case.
