04-12-2010, 08:19 PM   #1
suzuki-j's Avatar
Need help : k-x + tamron 90mm 2.8 di macro + image 2x TC = F-- flashing
Im kind of new to dslr so maybe im forgetting a dumb thing but here it goes:
just bought a Tele converter to use with my k-x and tamron 90mm 2.8 di macro. Paid 10$ for it and its a Image MC auto tele converter 2x for PK
the problem is that it worked the first time i tried it... at first it was very dark but then i turned the aperture ring on the 90mm lens and it was ok... took a couple photos and removed it. Now i put it back to try some more testing and it seems that every mode i use i see a F-- flashing and cant seem to be able to change any settings. when i try to shoot the screen goes black and no photo is taken
when it worked i was in M or AV
there doesnt seem to have any electrical contact but has pin hanging out
anyone can help... i know its probably dumb cause it worked for 3-4 pics
thanks
04-12-2010, 09:28 PM   #2
Hi suzuki-j,
The most common reason for the F-- is that the aperture ring on the lens is not set to the "A" position. There should be a button on the aperture ring that needs to be pressed to rotate the ring to the "A" position, and it should then lock there. Other than that, dirty contacts is the second most common problem. Usually a wipe with a clean lintless cloth is enough to clean the pins on the lens and the mount on the body. With the TC, you have two sets of pins, so it's a good idea to clean them all.
Scott
04-12-2010, 10:25 PM   #3
suzuki-j's Avatar
thanks but after playing with settings #22 allow aperture ring settings or something like that ... its working
for 10$ its nice to play with
thanks again your comment pointed me to the right track
90mm, 90mm 2.8 di, converter, di, k-mount, pentax lens, slr lens, tele
For Sale - Sold: Vivitar S1 105mm f2.5 1:1 Macro; Tamron SP 90mm f2.8 1:1 Macro; Pentax-F 1.7X thomasxie Sold Items 4 02-02-2010 05:40 AM
Which is the better the Tamron 28-75mm or the Tamron 90mm macro? rustynail925 Pentax SLR Lens Discussion 17 02-01-2010 10:30 AM
For Sale - Sold: Pentax K100d + 18-55mm + Tamron 70-300mm; Tamron 90mm Macro jake123 Sold Items 4 11-09-2009 12:51 PM
Sigma 70mm Macro or Tamron 90mm Macro? Pentakun Pentax SLR Lens Discussion 19 08-01-2008 06:56 AM
For Sale - Sold: Tamron SP 90mm/2.8 macro (AF), Tamron SP 90mm/2.5 macro (MF) chemxaj Sold Items 11 06-19-2008 08:36 PM
All times are GMT -7. The time now is 02:43 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
