04-13-2010, 07:29 AM   #1
Zebooka's Avatar
Sigma 70-300mm/4.0-5.6 DG OS
Thread about Sigma 70-300/4.0-5.6 DG OS stabilized!
Does anyone have it? Or tested? How good it is?
I'm considering it as animal/wild-life tele zoom. Optical stab. will help a lot in tracking moving objects.
04-13-2010, 08:42 AM   #2
Jodokast96's Avatar
Unless it's optically better (doubt it) than the previous version, I don't see OS giving a big (if any) advantage over SR.
04-13-2010, 08:56 PM   #3
Zebooka's Avatar
QuoteOriginally posted by Jodokast96 Quote
optical (lens based) stabilizer is known to be better at long tele range than sensor based ones. Also, it provides photographer comfortable tracking of subject without terrible shaking of picture in viewfinder.
Cheers
PS: I think I'll buy it. And report here the results and test shots. Some people on other forums reported it is much sharper that 70-300 lenses without OS.
04-13-2010, 08:58 PM   #4
jct us101's Avatar
I've actually been a lot more curious about the Sigma 50-200mm that was announced not too long ago but then never mentioned again. I would love to get that lens instead though.
04-13-2010, 09:47 PM   #5
Well, the OS version has a different optical formula than the current APO version, so there is hope that it's in the same ballpark as the Pentax 55-300 in terms of sharpness.
Just from personal usage, I've found that P&S with OIS (Canon) gives better SR than CCD-shift IS (Casio, Fuji). However, watching the image floating around in the Canon's OVF made me vaguely seasick.
04-13-2010, 10:53 PM   #6
Zebooka's Avatar
QuoteOriginally posted by flippedgazelle Quote
Totally agree for wide-angle.
I looked through Canon 40D + 17-55/2.8 IS USM. It is terrible.
04-13-2010, 11:03 PM   #7
lurchlarson's Avatar
The image quality should be fine. But I tend to agree that the OS won't do much. The two systems work about as well as the other.
04-14-2010, 01:02 AM   #8
KjetilH's Avatar
QuoteOriginally posted by Zebooka Quote
Out of curiousity, are there tests that confirm this?
The common argument seems to be that "VR/IS/OS/VC is suited to the lens itself, and is therefore more effective", but I have yet to see some numbers backing this up.
Regardless, it's nice to have the option, as well as it makes it easier for Sigma to release K-mount lenses.
04-14-2010, 03:10 AM   #9
Jodokast96's Avatar
So unless it's optically better than the 55-300, why fall into the Canikon trap of spending hundreds more for a lens that gives you the same 2-4 stops extra that SR does? The one review I read was pretty disappointed with the OS capabilities of this lens anyway.
04-15-2010, 12:58 AM   #10
jct us101's Avatar
Yeah, I would have to say that the old Sigma 70-300mm lens might be an option too since you don't need the extra Shake Reduction, but I haven't really read any reviews about this lens so I don't know too much about the quality of it compared to the older one. The older one was nice and all about it really was just a beginners lens, not someone who would ever pixel peep.
04-15-2010, 08:31 AM   #11
Zebooka's Avatar
QuoteOriginally posted by jct us101 Quote
The new one is sharper than old ones. It was shown on penta-club.ru
Sigma 70-300/4.0-5.6 DG OS - Форумы Пента-клуба
Also Optical Stabilizer is exactly what I need - I need stabilized picture in viewfinder for comfortable shooting.
Also Falk Lumo tested Sr here Falk Lumo: Pentax shake reduction revisited
It is not efficient at tele range as I've said.
Cheers
04-15-2010, 04:19 PM   #12
jct us101's Avatar
Cheers
If you have a Pentax DSLR that has built in Shake Reduction then it's going to turn off the lenses OS anyways, so it's kind of redundant for no reason.
04-15-2010, 06:06 PM   #13
Jodokast96's Avatar
You can use either (or even both).
04-15-2010, 08:26 PM   #14
Zebooka's Avatar
Who told you this?
You can always turn SR off and use OS in the lens.
04-15-2010, 08:45 PM   #15
jct us101's Avatar
Who told you this?
Someone on this forum, actually. I guess I should have looked for a second opinion. So if you just turn the cameras Shake Reduction off, the OS will work instead? Maybe the person meant that you can't use them both at the same time, which would make a lot more sense. I assume that you can't use them both at the same time? That would be a little redundant, wouldn't it?
dg, k-mount, os, pentax lens, sigma, slr lens
Pentax 55-300mm versus Sigma 70-300mm DG APO Macro mazdamazda Pentax SLR Lens Discussion 49 07-27-2010 12:46 AM
Tamron AF 70-300mm or Sigma Lens 70-300mm or Sigma 70-200mm Ben Hunt Pentax SLR Lens Discussion 21 11-05-2008 05:47 AM
Sigma 100-300mm f/4 versus Pentax DA* 300mm f/4 Tbear Pentax SLR Lens Discussion 5 03-26-2008 07:24 PM
If you had a choice: Sigma 300mm f/2.8 EX DG vs. Pentax FA* 300mm f/2.8 ED IF [NOS?] m8o Pentax SLR Lens Discussion 10 07-27-2007 07:27 AM
All times are GMT -7. The time now is 06:48 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
