07-22-2007, 12:45 PM   #16
Fl_Gulfer's Avatar
2, 1, 2, have better color thats why I said the 18x55.
07-22-2007, 12:54 PM   #17
Bryce's Avatar
If you really want to see the difference between the two lenses, however large or small, you'll have to try images that challenge the optics. Here are some examples of 'challenging' images:
1) Heavily backlit scenes or ones with the sun in the frame. Look for specular and veiling flare.
2) Wide open for shallow DOF and/ or low light use. Especially in combination with #1. Also, the appearance of unsharp areas may (or may not) be important to you.
3) Face on views of architecture where small amounts of distortion become obvious. This is less important with digital since distortion can be easily corrected with P-shop.
Even at F/9 and flat lighting, the greater contrast of the 31mm lens is pretty obvious to my eye, though I'd be happy with either.
I guess the bottom line is whether the lens you choose works to your satisfaction for your purposes. There are a lot of tradeoffs between the kit zoom and an expensive prime. Obviously the zoom has the advantage of versatility and cost; the prime is a wee bit faster to use and more compact, as well as offering much more speed.
07-23-2007, 05:54 PM   #18
Mallee Boy's Avatar
I don't know about anyone else...but I have found this thread very interesting, helpful and informative.
Thankyou Bart for prompting the thought process.
Grant
copy, k-mount, kit, lens, pentax lens, shots, slr lens
Are you satisfied with the K-x image quality? rjm Pentax DSLR Discussion 37 01-21-2010 06:27 AM
How can I get good image quality from a K-x?? Manfred Troubleshooting and Beginner Help 38 12-20-2009 08:18 PM
K or M Series - Which has the best image quality 8540tomg Pentax SLR Lens Discussion 20 10-05-2009 07:53 AM
K-7 image quality concern claude21 Pentax DSLR Discussion 31 06-26-2009 11:34 AM
DA 16-45mm image quality sveinmb Pentax SLR Lens Discussion 25 09-18-2008 03:58 PM
All times are GMT -7. The time now is 02:39 PM. | See also: NikonForums.com, part of our network of photo forums!
