04-13-2010, 08:15 PM   #1
Pentax pk mount
just bought a manual 135mm lens with p/k mount it seems it won't fit with my pentax k-x is there an adaptor for this? really confused..
04-13-2010, 08:19 PM   #2
Pentaxor's Avatar
are you sure it's p/k ? that seems weird. any other info details or picture on what kind of lens it is?
04-13-2010, 08:34 PM   #3
there is p/k that was inscribe at the lens mount (don't have image showing them), this is the same lens
04-13-2010, 09:25 PM   #4
pacerr's Avatar
We'd need to see the mount to be sure, but I'd almost bet there's a very broad flange that protects the moveable aperture lever. Compare it to a Pentax lens. If that's the problem, the guard can be removed or reduced to PK proportions.
H2
04-13-2010, 09:29 PM   #5
Pentaxor's Avatar
QuoteOriginally posted by daXmp Quote
do you have a photo of the mount as well? I cant seem to see how the mount looks or have a clear idea. it could be that the flange is bigger eventhough it appears to be a p/k lens.
04-13-2010, 09:37 PM   #6
i will take picture later, and show you guys.. thank you for your replies..
04-14-2010, 05:58 AM   #7
here is the photo of the mount it has a p/k engrave on it and it has a metal flange.. how come it won't fit on my pentax k-x?
04-14-2010, 06:17 AM   #8
axl
what you mean by "won't fit"
will not mount at all?
will not lock?
04-14-2010, 06:22 AM   #9
Senior Moderator
Nass's Avatar
Be careful. have a read of these threads:
Doesn't look to me like this Albinar lens mount is actually properly compatible
04-14-2010, 06:54 AM   #10
The lens he has is not a Ricoh pinned lens. It is a plain manual one. I have several of that same lens, and they fit my cameras no problem.
04-14-2010, 07:04 AM   #11
axl
I wanted to point out the same. It doesn't seem to P/K R lens which would suggest Ricoh mount.
Even if, than I'd expect the lens to mount, but get stuck.
That's why I've asked what does "won't fit"mean...
04-14-2010, 07:16 AM   #12
QuoteOriginally posted by axl Quote
will not lock?
what i meant was it won't lock..
04-14-2010, 07:23 AM   #13
I've had this with 3rd party lenses before. Usually the notch at the end nearest the inside is too shallow. It comes from the cheaper machining methods used. I've used a Dremel to deepen it and sometimes widen a hair. Tolerances on the cheaper lenses was sometimes hit or miss.
04-14-2010, 08:57 AM   #14
Blue's Avatar
If it were PK/R i.e. Pentax/Ricoh mount, it would also be A compatible. That lens is not A.
04-14-2010, 11:43 AM   #15
axl
well, I think the wildlifephotog hit the nail then.
If the lens will turn as much as is should, the only reason for it not to lock is if the "hole" for locking pin is:
a) too shallow
b) misaligned
in any of those two situations dremel should help, but please don't ask me, I've never done it
k-mount, pentax, pentax lens, pentax pk, slr lens
adapters for non-K-mount lenses to Pentax K-mount DSLRs: new dimensions for LBA Douglas_of_Sweden Pentax Camera and Field Accessories 152 07-29-2017 05:47 AM
For Sale - Sold: Genuine Pentax Mount Adapter K (M42 to K-mount) zx-m Sold Items 6 01-30-2009 01:22 AM
For Sale - Sold: *New* Pentax Mount Adapter-K M42 to K-Mount X Man Sold Items 4 12-31-2008 04:10 PM
For Sale - Sold: FA: Original PENTAX Screw Mount to K Mount Adapter M42 HogRider Sold Items 0 10-21-2007 02:12 PM
All times are GMT -7. The time now is 10:49 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
