11-05-2010, 08:07 PM   #46
rparmar's Avatar
Nice look to that one!
11-06-2010, 12:14 AM   #47
Digitalis's Avatar
QuoteOriginally posted by rparmar Quote
The purple fringing at f/1.2 can be severe
yes it can be bad, I would rate it as not being as bad as the FA77 about the same as the FA31 in terms of PF. The SMCP-K 50mm f/1.2 is streets ahead of the competing Canon 50mm f/1.2 which has significant purple fringing all the way to f/8. The Carl zeiss Planar 50mm f/1.4 is also a poor performer in terms of Purple Fringing - it seems to be a characteristic of contrasty lenses.
12-23-2011, 09:37 AM   #48
Frogfish's Avatar
OK today I dropped off a lens for some TLC at the repair shop and as is my wont I traipsed around 5 floors of the camera mall to see what other used lenses were new in all the little retail shops. I came across a K50/1.2 on a K2 and the owner of the shop will split them (US$350 for the 50/1.2 and US$65 for the K2). I ran a few test shots and loved it, it's in lovely condition even if the focusing ring seems very firm (anyone's else's like this) ?
Oh woe is me ! I already have a Cosina 50/1.2 (I love that too) but like Peter (Axl) I'm just enamoured with low DoF and sweet OOF. So maybe the 77 can wait a little and I can pick this up next week. Anyone have any pearls of wisdom to tender ?
12-23-2011, 10:05 AM   #49
baro-nite's Avatar
That's a rather good price, especially for the condition. My K lenses all have pretty firm focus rings, as compared to my M lenses. You can get a 77 any time. You're not going to lose money if you buy this one and then decide to sell it.
12-23-2011, 10:07 AM   #50
axl
K50 is worth every cent you pay for it. I only sold mine because for some weird reason I could not focus anything manually on my K-7. 77 is sharper up to 2.8, maybe even after that but in overall IQ the "old lady" spanks the Ltd.
My 2p
12-23-2011, 04:20 PM   #51
Digitalis's Avatar
As I said earlier the PF from the Pentax 50mm f/1.2 isn't bad at all - even in broad daylight, at least with my copy of the lens. What strikes me as rather curious is there is a stop difference between the shutter speeds I set for the FA77 and 50mm but the image from the 50mm f/1.2 seems to be brighter by nearly 1/3 of a stop.
Wb set to 5000K - no alterations beyond the LR default RAW settings.
12-24-2011, 03:01 AM   #52
Frogfish's Avatar
QuoteOriginally posted by baro-nite Quote
Yep. I think so. I'm just about decided that this is the way to go.
12-24-2011, 03:03 AM   #53
Frogfish's Avatar
QuoteOriginally posted by axl Quote
My 2p
Ha ha that doesn't help because I don't use my current f1.2 lens at anything over f2.0 ... max ! I found focusing it in the shop very easy, even with CIF (focusing from close to infinity). Thanks Peter.
12-24-2011, 03:09 AM   #54
Frogfish's Avatar
So the 50 was set to f1.2 and the 77 to f1.8 with a faster shutter time of 1/1,600 to compensate for the one stop difference ? Or was the 50 also set to f1.8 ? I'm not quite sure what 's going on there !
12-24-2011, 06:57 AM   #55
Digitalis's Avatar
QuoteOriginally posted by Frogfish Quote
What shutter speed lets in one stop less light than 1/1600th? the correct answer is 1/3200th. Yes I had the pentax 50mm f/1.2 @ f/1.2 - the purple fringing from the pentax 50mm f/1.2 isn't anywhere near as bad as the FA77 and curiously still the image from the 50mm f/1.2 is slightly brighter than it should be.
12-24-2011, 07:24 AM   #56
hoanpham's Avatar
I have both k50/1.2 and A50/1.2.
The samples from A50/1.2 are here
https://picasaweb.google.com/111102833818394930252/A50f12
Look at the photos of the motorbike. Taken at f1.2, 1.4 and 2.0. CA and PF at 1.2, but very ok at 2.0.
12-24-2011, 11:32 AM   #57
Frogfish's Avatar
What shutter speed lets in one stop less light than 1/1600th? the correct answer is 1/3200th. Yes I had the pentax 50mm f/1.2 @ f/1.2 - the purple fringong from the pentax 50mm f/1.2 isn't anywhere near as bad as the FA77 and curiously still the image from the 50mm f/1.2 is slightly brighter than it should be.
Yes I got that as I suggested .... however the 50 shot didn't have an aperture value assigned to it so as I said I thought that was what you had done to compensate but wanted to be sure. I had noticed how bad the PF was on the 77 during in-shop testing (vs. the Sigma 85 which is at least as bad).
As for the 1/3 stop difference ... as I'm sure you know occasionally lenses aren't exactly the aperture they are purported to be, so that could easily be the 77 being a 1.9 or the 50 a 1.1.
One thing I did notice in the copy I looked at is that the blades didn't lay perfectly flat on top of each other .. is this normal ?
12-24-2011, 11:37 AM   #58
Frogfish's Avatar
QuoteOriginally posted by hoanpham Quote
Thanks HP. The shot of the iron railing against the brick wall is quite a compelling argument. Sharp, great bokeh and isolation .. exactly what I want.
12-24-2011, 04:29 PM   #59
Digitalis's Avatar
With my FA77 the blades lie perfectly flat.
12-24-2011, 08:51 PM   #60
Frogfish's Avatar
Sorry I was referring to the K50/1.2
f/1.2, filter, hood, k-mount, lens, light, pentax lens, shot, shots, slr lens, test, tests
The real world difference f/1.4 -vs- f/2 Oscar1 Pentax SLR Lens Discussion 13 02-06-2010 10:33 PM
Some K-7 Real World images yakiniku Pentax DSLR Discussion 12 08-02-2009 09:13 PM
Snowflakes in the real world MightyMike Post Your Photos! 6 12-23-2008 06:40 AM
CA in the DA*16-50 vs Tamron 28-75 in real world 123K10D Pentax SLR Lens Discussion 10 02-23-2008 02:44 PM
Real world use. Rob.K Pentax DSLR Discussion 29 02-12-2007 01:26 PM
All times are GMT -7. The time now is 02:52 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
