04-15-2010, 02:07 PM   #1
Tamron 28-75mm f2.8 or Sigma 24-70mm f2.8?
Wich (in your opinion) is the better lens? Are there any "real life" differences in IQ?
04-15-2010, 03:33 PM   #2
Moderator Emeritus
I haven't used the Sigma and I think thaer are far fewer owners of it. But the Tamron is very hard to beat. It's smaller and lighter than the Sigma and sharp from wide open with decent close focus ability. I'd put that on the top of the list.
You should check the lens review data base for both here.
04-15-2010, 03:42 PM   #3
don't leave out the Tokina AT-X 28-80mm F2.8 SD AF PRO
04-15-2010, 03:48 PM   #4
Moderator Emeritus
Luke, that would be great and a nice lens, even if it is much heavier than the other 2. But it's nearly impossible to find and long out of production.
04-15-2010, 04:12 PM   #5
jct us101's Avatar
The Tamron is the best lens there. Unless you get the newer HSM Sigma 24-70mm, then it's going to have an 82mm filter size, which will probably amaze you by the overall size of it and the lens. The tamron is a much smaller (and a little bit lighter, but much sturdier feeling) lens that also has some great quality to it. It's also the only lens that I've seen almost double it's used value in less than a year, so I would definitely recommend it.
04-15-2010, 04:57 PM   #6
PinarelloOnly's Avatar
I'm set on the Tamron 28-75 as my next zoom down the road.
I also considered the Sigma 24-70mm but after actually handling the Sigma at
B&H in NY last summer, I'm not interested in such a large lens.
Don't get me wrong itís not a negative, the Sigma 24-70mm really is a nice lens
but it's a ridiculously big lens in a cool way if you like a large heavy glass, just not
for me and something to consider in your type of shooting that you do.
04-15-2010, 05:29 PM   #7
Lowell Goudge's Avatar
when I went through this process I settled on the tamron, I looked at not only the sigma 24-70 but also the 24 - 60
The deciding factor was the filter size, I had a lot of 67 mm filters
04-15-2010, 10:12 PM   #8
Pentaxor's Avatar
Tamron 24-75
pros:
better IQ than the Sigma although Sigma is already have excellent IQ (not worse but great as well).
smaller and lighter.
cons:
QC maybe inconsistent and may have some issues (hit or miss) but you have 6 years warranty
lesser wide view (only 28mm)
Sigma 24-70
pros:
great IQ
wide FOV at 24mm
cons:
big and heavy
04-16-2010, 05:51 AM   #9
QuoteOriginally posted by Pentaxor Quote
Tamron 24-75
pros:
cons:
Sigma 24-70
pros:
great IQ
wide FOV at 24mm
cons:
big and heavy
All of your points are valid, and were part of my decision process as well when I took the tamron, to fit between my sigma 10-20 and 70-200. The gap between 20 and 28 mm concerned me a little, but in the end, what made the difference is that at the time I bought it, I already had 2 different 67mm graduated ND filters and a polarizer because I already had 2 other lenses with this filter diameter. THose filters cost a lot, and when you go to the 82mm diameter of the sigma, almost double again. You need to think system a little. As for the gap, I have an FA-J 18-35 (which also uses 67 mm filters) so it was not a real issue for me.
04-16-2010, 07:26 AM   #10
The 28-75 has better image quality (less flare) than the 24-70 (unless you mean the HSM which is better than Canon's L glass). The problem w/ all of these is quality control sucks. I went through 3 copies of the Tamron before giving up...BF/FF issues, haloing, etc. Haven't figured out whether to look at the HSM or keep trying Tamron roulette...
04-17-2010, 03:59 AM   #11
bfo
QuoteOriginally posted by kenyee Quote
I ment the non-HSM. But that was because I thought the HSM and non-HSM were similar optically. If they are not I guess I have to consider the HSM seriously. I'm afraid this will get rather expensive
04-17-2010, 04:00 AM   #12
bfo
...and by the way, Thanks for your feedback guys.
04-17-2010, 04:56 PM   #13
jct us101's Avatar
If it's front of rear focusing, Tamron will take it in for free, at least with this lens. I've seen people do that and not get charged because it's a pretty big problem (Sigma does the same thing with it's 24-60mm lens which has the same problem). I agree that too many of these lenses have a lot of quality control problems though.
04-30-2010, 05:54 PM   #14
NeverSatisfied's Avatar
QuoteOriginally posted by bfo Quote
Their optical formulas are different. The HSM is said to be a good lens but it's awfully expensive in comparison, and like Lowell said, 82mm filters, $$.
04-30-2010, 06:29 PM   #15
philbaum's Avatar
I just bought the Tamron 28-75 within the last month and its everything people said it was:
sharp as a tack
the zoom is a little stiff to move, but i like it that way - no lens creep so far
lightweight and balances very well with my K20
haven't noticed any focus problems with it.
k-mount, pentax lens, sigma 24-70mm, slr lens, tamron 28-75mm f2.8
Wanted - Acquired: sigma 17-70mm or tamron 28-75mm f/2.8 kjfaust Sold Items 1 01-26-2010 07:25 PM
For Sale - Sold: Pentax DA50-200mm, FA50mm, M50mm f2, Sigma 24-70mm, Tamron 28-75mm ndy4eva Sold Items 9 09-04-2009 09:20 AM
For Sale - Sold: Two lens for sell- DA 70mm/2.4 and Tamron 28-75mm/2.8- In Box qqspm Sold Items 10 01-29-2009 08:50 PM
Pentax FA 28-70mm f/4 vs Tamron 28-75mm f/2.8 bc_the_path Pentax SLR Lens Discussion 8 02-21-2008 01:36 PM
All times are GMT -7. The time now is 04:28 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
