Originally posted by kyteflyer I think I've decided to start with the DA 35mm macro. Its going to be okay for me to start with because I'm thinking I want to just wander about with a single lightweight lens for most purposes. Besides, I need to just get out there and do it.
Sounds to me like you've got everything thought out very well, in fact. Starting with the DA35 is entirely logical... except that then you will likely not get the FA43 for a while (if ever) -- and that is a shame.
My next lens would be the FA77. It is significantly different in focal length and a stop faster.
Next, go the other way for the DA15 or perhaps an alternative? The prime is great if size is your main concern, but in the wide end I find primes to be far too restrictive. Every mm makes a big difference to FOV. 12mm is totally different from 15, 18 and 24. Which is why I recommend the DA12-24, to cover all of these with IQ that is second-to-none.
Otherwise, budget for a fast 24mm lens as well. The gap from 15 to 35 is just too big.
I do however think you can do without the 90mm macro since you can get a Raynox adapter and put it on the FA77.
